Old March 30, 2009, 08:57 AM
486's Avatar
486 486 is offline
Default S-Flex Fans
I have noticed that 120mm S-Flex fans F (1600) emit very low freq hum even at 800-1000 RPM. Did anyone else notice it?
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
Kingstone HyperX 2 x 8GB
Crucial M4 256GB + 128 GB
Sapphire Radeon HD7970
Nec Multisync LCD2690WUXI
Old March 30, 2009, 08:59 AM
CMetaphor's Avatar
Quadfather
Yup, I very much don't like that noise. I had two 1600rpm s-flex fans on my TRUE from my last system and they would hum in that matter at around 8-10v. Replaced those gus quick... But now they're gone anyways, hehe.
Old March 30, 2009, 09:47 AM
MpG's Avatar
MpG MpG is offline
Depends on the fan, I find. I've got half a dozen F's, and while most of them undervolt perfectly, one or two of them aren't as cooperative in the 7-10V range. They clear up around the 5V mark, though.
Old March 30, 2009, 09:49 AM
ChuckleBrother's Avatar
Weird, I must be lucky because I've never heard my fans. I run them down to about 900RPM and I can't even hear them over over my pump/PSU.
"...you play a mean banjo"
Anyone have one of these fans? Realityshift Air Cooling 11 March 12, 2009 08:44 PM
Fans for PA120.2? 3.0charlie Water Cooling 33 July 19, 2008 10:48 AM
What are the quietest fans? Sniper Off Topic 20 June 3, 2008 01:36 PM
OCZ Unveiled PC3-1600 CL8-8-8 Flex II Series Hardware Canucks RAM 0 April 22, 2008 01:31 PM
TechGage reviews the OCZ 2GB Flex XLC PC2-9200 Babrbarossa Reviews & Articles from the Web 0 March 7, 2007 11:59 AM
