<~----> Ultra 120 eXtreme issues - Hardware Canucks
Old March 27, 2009, 07:04 AM
Chos3n's Avatar
Default Ultra 120 eXtreme issues
Hello guys,
I have an issue with my Ultra 120 eXtreme. I just installed it with OCZ Silver thermal paste (I'm waiting on my IC7) and also installed it with 2 Noctua SP12 in a Push/Pull configuration. I started my PC and started Core Temp. My E8500 is idling at 39 - 41... which is really weird. I used Real Temp (In the past Core Temp wasn't really good with Wolfdale) and it gave me the same results. When I had my Intel Heatsink, I was idling at 49 - 51, but still I saw some people getting 19 - 21 with the Ultra 120 and a E8400.
Something that bothers me is that I can twist my heatsink (it moves). But the problem is, it tighten all the way down. I contacted Thermalright and ask them if it was normal and they answered yes. So, I dunno if it's my fan that aren't pushing enough air, or if I should washer mod my Ultra 120 eXtreme.
Here's some pics:
Initial Setup.
The back exhaust fan is a low, and it barely moving any air. The bottom fan (from my heatsink) is pulling air into my Ultra 120, and the top and the Big Boy push it outside the case (there a nice breeze on top of that fan )
Thanks
BTW, those fan headers are a breeze to setup, take that fan clips.
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
CPU Intel Core i7 2700K 3.5GHZ
Motherboard ASUS P8Z68-V
Memory Corsair Vengeance Blue 8GB 2X4GB DDR3-1600 CL9-9-9-24
Video Card MSI GeForce GTX 560 Ti Twin Frozr II
Sound Card ASUS Xonar DX
Old March 27, 2009, 07:08 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
19-21? sub-ambient? I think not.
Here are some options:
- Install a rubber washer or dime between the cooler and the bracket
- Use a higher RPM fan or add another fan for a push / pull setup.
Old March 27, 2009, 07:21 AM
Chos3n's Avatar
That's what I though too, those were case fan (but they came with the heatsink, that was a good deal I got ). Tonight, I'll try the load temps, I was just skeptical to try load temp with those idle temps.
So a dime would do it? Wouldn't it be off balance considering the size of the dime?
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
Old March 27, 2009, 07:22 AM
3.0charlie's Avatar
Air sub-ambiant is impossible.
I would verify how flat both HSF and IHS are. You may need a lap job. And by the same token, check your TIM application.
My TRUE always rotated once installed.
Old March 27, 2009, 07:24 AM
CMetaphor's Avatar
Quadfather
I'll take one?
Old March 27, 2009, 07:26 AM
Chos3n's Avatar
I wouldn't go to the step of lapping my CPU... considering I won't overclock ( maybe a mild overclock, nothing extreme). Also, the fact that I need to sand my precious CPU .
Have you done the dime/washer mod. Also, what are your temperatures now with the Ultra 120 ?.
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
Old March 27, 2009, 07:39 AM
SKYMTL's Avatar
What kind of fan do you have on the TRUE? Also, take the temperatures before the dime application method.
Old March 27, 2009, 07:47 AM
3oh6's Avatar
Hardware Canucks Reviewer
idle temps are all but useless as they are more dependant on ambient air temperature than anything. with that said, you still saw a 10C drop from the stock heat sink which is pretty substantial at idle. check load and go from there. only make conclusions based on load temps.
Old March 27, 2009, 07:51 AM
MpG's Avatar
MpG MpG is offline
Are those Noctua S-series fans you're using? Even Noctua warns against using them for restrictive applications such as heatsinks and radiators. While it's hard to give specific numbers, there are almost certainly better fans for you to be using on a dense-fin heatsink like the TRUE. Put those fans on case intake/exhaust, I'd say.
Old March 27, 2009, 08:09 AM
Chos3n's Avatar
Noctua SP12 ... but I guess I'll change them. I know they are low CFM... but since I had two I said that it would have been the equivalent of the 1 . I will take the temperatures in note. Looks like I need to take off my motherboard from my case again... such a pain.
I will do that tonight, if the heatsink is more stabe at load, I will be happy.
Yeah thats a SP12, they are low CFM. But I said considering I put two of them, that it would suffice. I know there are better fan with higher CFM, but I got these fans with it and didn't really want to get other fans (budget wise).
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
Thermalright Ultra 120 Extreme Mulder Air Cooling 5 September 30, 2008 12:37 AM
WTB Thermalright Ultra 120 Extreme rom0n Buy/Sell & Trade 18 June 1, 2008 01:43 PM
Ultra 120 Extreme Base enaberif Overclocking, Tweaking and Benchmarking 13 January 22, 2008 08:37 PM
Where oh where to get a TR-120 Ultra Extreme? Dus Water Cooling 5 September 27, 2007 08:19 PM
A second look at the Thermalright Ultra 120 eXtreme Babrbarossa Reviews & Articles from the Web 2 May 4, 2007 06:23 PM
