Old March 24, 2009, 06:20 PM
Default HAF cooling
Hey guys. All you HAF owners out there did you leave the cooling stock or did you install 140mm or 120mm instead of the huge stock fans. Just wondering what works best for overall cooling while remaining fairly quiet.
Old March 24, 2009, 06:45 PM
Ging9's Avatar
I've kept all the stock fans...I don't find them particularly noisy, and temps have dropped across the board by 5-10 degrees celsius. For example, my OC'd Xeon 3110 now idles at 31 degrees...it used to run around 35. My 4870 idles in the mid 40s vs. high 70s, but I'm not sure how much that's due to the Akasa Vortexx I installed in place of the stock cooler.
Asus P8P67 Deluxe, i5 2500K, MSI 560 GTX Ti, Corsair 600T, 4X2 GB Kingston 1600, Corsair H60, PC P&C 750.
Old March 25, 2009, 04:00 AM
I left mine stock, with the exception of adding a 120 inlet in the bottom of the case next to my PSU. The three stock 230's and the one 140 spin at a low RPM, so there's not a lot of noise and because of the size of their blades they're able to move a rather amazing amount of air. I equate that to having the best of two worlds and look for more manufactures to move to larger fans in their full size tower cases.
Old March 25, 2009, 04:06 AM
Mine are stock. DOn't really hear the fans. In fact the only thing I hear running now is my power supply. Think I need an ultra quiet supply, its driving me crazy.
RIG #1 - Intel E8400 // TRU-X 120 w noctua NF-P12 // GA-X38-DQ6 // GTX285 OC // 8g Ram OCZ Fatal1ty PC8500 // X-Fi Elite Pro sound // z-5500 speakers // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Seagate 1Tb // 2xSeagate 500g ex// Logitec G-15 keyboard // Vista Ultimate 64bit
RIG #2 - AMD64 3500+ // Asus A8N-E // 8800GTS 512 OC // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
Old March 25, 2009, 07:07 AM
I'm using the stock ones too.. I added a 120 mm fan in the bottom that's all! The loudest thing in my case is my GPU!
Back up - Ebay (Inik1) or Heatware
Old March 25, 2009, 11:02 AM
What direction do you guys have the 120s moving. In or out?
Old March 25, 2009, 01:37 PM
In.. so my GPU can get fresh air
Old March 25, 2009, 06:58 PM
I'm running stock and it's really quiet, I think the 120mm mounting holes are mostly there for radiators and things like that.
Q6600 G0 @ 3.0GHz - P5Q-E - EVGA GTX 260 Core 216 - Corsair TX750 - Coolermaster HAF 932 - Xigmatek HDT-S1283 - Mushkin Redline 2x2gb
Old March 26, 2009, 04:46 AM
In to create a little positive pressure and blow on my GPU
Old March 26, 2009, 10:07 AM
Dar_ell's Avatar
I mostly left the stock cooling the same, i also modded 2 120mm fans on the HD cage(i don't really find a difference but meh..).
"My brother is dead. He's not here Anymore. But on my back, and in my heart...He lives on in me. I will make a hole through heaven itself, even if that hole becomes my grave. As long as I break through, I will be victorious.Who the **** do you think I am?"
RAM cooling CTA Air Cooling 11 September 2, 2008 08:01 AM
NB Cooling - What would you do? biff Water Cooling 18 April 21, 2008 08:48 AM
Cooling SLi? DSNB Troubleshooting 14 January 24, 2008 01:06 AM
TEC Cooling chibi_man Water Cooling 10 November 9, 2007 04:40 PM
How is my cooling? mattydies Water Cooling 6 August 9, 2007 08:12 AM
