Old March 21, 2009, 11:26 PM
MpG's Avatar
MpG MpG is offline
Originally Posted by rjbarker View Post
I've heard n read this "undervolting" fans in a few cases...what exactly is the benefit to this?....
You mean, "undervolting" in general? or the 5V trick?
Edit: You don't get voltage feedback with the 5V option, it's the 7V option that runs that risk. I don't particularly like the 7V option myself, for just that reason.
Old March 21, 2009, 11:51 PM
rjbarker's Avatar
I personally don't condone doing this as you can buy resistors to do this properly and not have to worry about voltage back feeding into components or your powersupply.
What do you mean Enab....you don't condone plugging in Case fans to Mobo Headers? I ask only because I had an odd "Cold Boot" error on my X58 Mobo / Rig and was basically at the point where I figured it was either the PSU or the Mobo causing the "issue"...
I have since sent the Mobo back to Evga (stepping up to Classified) and have RMA'd the PSU to Corsair.
That is interesting, I had 3 Scythe S Flex 120mm 1200 RPM fans and CPU fan plugged into headers only, 2 other fans plugged into Molex.....can you elaborate?
Firestrike Extreme: 21.452
MARK 11: 32.530
Old March 21, 2009, 11:54 PM
rjbarker's Avatar
Yeah I got this Enab no worries their....MPG posted as I was typing, I understand what you mean...
MARK 11: 32.530
different fans on each side of rad? (push pull) donimo Water Cooling 2 February 9, 2009 12:35 PM
How do you like my new rad? Push-Pull FTW!!! Sniper Water Cooling 26 December 8, 2008 09:09 AM
Fans for Push/Pull on PA120.2 Supergrover Water Cooling 20 September 14, 2008 07:18 PM
think this can pull 2x 8800gt in sli? mmmstew Power Supplies 13 May 26, 2008 01:27 AM
Push vs Pull on a Rad? Supergrover Water Cooling 10 October 16, 2007 07:13 PM
