Old March 12, 2009, 08:18 PM
JD JD is online now
Originally Posted by Realityshift View Post
damn, kinda going for the quieter fan, those coolermasters are high cfm with stupid low noise. but I might still take you up on that fan ST ill have to think about it. that kind of airflow might help with cooling =)
They are definitely way over-rated BTW. No way a 2000RPM 120mm fan only produces 19dBA. Maybe at like 1000RPM or lower.
I have a similar clear blue LED version of that fan. Far from silent when you run them at 12V, though it moves quite a bit of air. "Silent" has far less airflow and is actually quite minimal IMO. Mine came with a VR knob though so I can adjust the fan speed easily. Basically this: CM Store but clear w/ blue LEDs.
Old March 12, 2009, 08:44 PM
Realityshift's Avatar
Yeah I have 2 clears I could use if I wanted to, but I really like the effect of the lights on the black fins, thats the reason I wanted the dark knight version of this cooler over the stock.
EDIT: although LEDs where white still nice effect.
The Builders Hammer
230 mm replacement fans serenity Air Cooling 14 January 20, 2009 12:40 PM
Fans for PA120.2? 3.0charlie Water Cooling 33 July 19, 2008 10:48 AM
What are the quietest fans? Sniper Off Topic 20 June 3, 2008 01:36 PM
can PWM fans be used without PWM controllers? solaris10 Air Cooling 0 February 4, 2008 10:29 AM
Any Lacrosse Fans? MaDDN3ss Off Topic 1 January 27, 2008 09:35 PM
