Old March 12, 2009, 04:26 AM
Default Thermal Compound: All that and a bag of potato chips?
So I am still using my stock heatsink and was considering a new after market heatsink, but after dropping most of my money I had on a new video card, PSU, RAM and case fans, I think that idea will have to wait. However, while I was researching different heatsinks I came across a few people saying that simply applying new thermal compound on their stock heatsinks gave them drops of up to 10 degrees celcius. Is there any truth to this? Did the manufacturers really do that poor of a job with their own? If I can expect to see even a 5 degree drop I'd go out and pick out a tube.
This leads to another question. What thermal compound do you all recommend getting? I remember when I first built my computer two years ago arctic silver 5 was the shaz! But is it still what I want to be getting? I notice arctic silver has a few more compounds out there now incorporating fancy words into their names such as: ceraminque, ceramic polysynthetic and high-density polysythentic. Is all this just marketing hype and plain ol' arctic silver 5 is still leading the pack, or should I actually look into picking up something with a fancy name?
Just so you know, I'm running an athlon 64 x2 3800+ on a MSI K9N Platinum mobo.
Old March 12, 2009, 04:38 AM
Varroa's Avatar
First of all, what HSF are you using? The stock one? What are your temps?
Second, No, you won't notice a 10 degree drop. 5 degree MAYBE depending on what thermal compound was used originally. AS5 is no longer the top dog (but still a decent compound). Try some Artic Cooling MX, it works better and spreads easier. There are diamond based stuff as well that is better but super expensive.
GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 2x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
Old March 12, 2009, 04:53 AM
Yeah, still using the stock fan as well. I get 33 degrees idle, haven't tested full load temps yet. I used to use nvidia's ntune monitor program to keep an eye on my temps, but lately the window doesn't open to the full size so I can't see the temps or the voltages, and it won't resize. So I just recently downloaded speedfan to control my fans and something else (the name eludes me at the moment, and I'm at work so I can't check) to check my temps. Thus, I haven't really had a chance to do a full load test yet.
Old March 12, 2009, 05:28 AM
Soultribunal's Avatar
The stuff on the STock Intel/Stock AMD Cooling Fans is not the best stuff out there.
The people posting 10 degree differences probably didn't have their HSF seated right to begin with.
It does make a difference, though using a good quality thermal Paste.
My favorite is from OCZ, their OCZ Freeze variety.
I have had no issues using it, and it never needs to cure to be effective.
Remember , if you are replacing your Original Thermal Grease, to use rubbing alcohol to clean the surfaces (the Heatsink and the Processor). But, use something that does not leave lint or anything of that sort (an example, I use the same cloths that clean my Oakley Sunglasses) so that way you don't damage the Processor or anything else when you are done.
Good Luck,
ST
Old March 12, 2009, 05:32 AM
ST
The stuff intel uses has been said to be up there with the qualities of Arctic Silver 5 and works perfectly fine for stock to VERY mild overclocks.
But regardless of any situation if your thinking of doing major overclocking you need to get a new hsf.
Old March 12, 2009, 05:36 AM
burebista's Avatar
Take a look.
Old March 12, 2009, 05:56 AM
Maybe they have changed it since I had my experiences with it. I haven't used a Stock HSF in a long Time Enaberif, so I could very well be mistaken on that one.
Still, I am a Fan of the one I use.
Regards,
ST
Old March 12, 2009, 06:02 AM
MpG's Avatar
MpG MpG is offline
Where you really notice the difference is often in the chipset. Especially on cheaper boards, manufacturers are often sloppy with how they stick their heatsinks on the regulators and chipset spots, so in some cases, I could see 5-10 degrees improvement being possible. On the CPU itself, probably not so much, but still posible to see a few degrees improvement. Most important is getting a good spread of paste - not too much, not too little. If you're serious about temperatures, you should be making multiple attempts,.
As for AS5, still good stuff, but it's not uncommon to see the newer compounds edging it out by a degree or two. One of the big advantages of many newer compounds are that they're non-capacitive, which is some peace of mind if you manage to get some where it shouldn't be (i.e. CPU socket).
Old March 12, 2009, 01:21 PM
Realityshift's Avatar
I dont think youd see a whole lot of difference, its not going to be the same as going from a good aftermarket cooler from the stock, id expect maybe a couple of degrees at best. One nice thing about it though is I find that the Core 2s 3 line application on the bottom of their coolers didnt make the best contact for me? I much rather applying it in my own pattern so i know its spreading evenly.
Thermal Compound Removal Help no_pulse Guides & How-to's 36 May 7, 2010 10:45 PM
Pre-Applied Thermal Compound element291 CPU's and Motherboards 3 January 8, 2009 10:21 PM
Best thermal compound? Cadence Air Cooling 10 December 14, 2008 05:17 PM
Thermal Compound Review no_pulse CPU's and Motherboards 5 July 23, 2008 01:50 PM
change of thermal compound v0maru CPU's and Motherboards 0 March 18, 2008 08:13 AM
