Old March 8, 2009, 04:21 PM
WolfBane's Avatar
Default CPU Heat sink
I have a system here that the plastic push pull pins are so cheap that they brake the little tabs and just won,t stay seated!!!
The MB is a 775i65g duel channel etc etc ,
A cheap MB huh ?
This is my wifes sytem and she really like to play pogo etc etc and i would like to get it goign for her !
That all being said whats a good permanant heat sink that will do this MB ?
I want it to have a back plate and be solid !
Also whats good tim for this or does enuff come with a new heat sink?
I USE EMT ONLY
Remember... Four boxes keep us free: the soap box, the ballot box, the jury box, and the cartridge box.
Old March 8, 2009, 05:47 PM
The MAX's Avatar
Well it doesn't sound like you're doing anything intensive on the mobo so you're not going to need anything heavy duty.
Cheapest HSF that looks decent I can find is this
NCIX.com - Buy Silverstone NT07-775 Nitrogon LGA775 15-23DBA Heatsink Fan - NT07-775 In Canada.
you can also buy a bolt thru kit to get rid of those pins.
NCIX.com - Buy Thermalright LGA775 BOLT-THRU Kit for Ultra 90/120 & HR-01 Retail Box - BTK-LGA775R In Canada.
I would also get some Arctic Cooling MX-2 to use as your tim, that seems to be the best stuff these days.
Push pins should be fine for a stock hsf. They're a pain, but once they get seated it shouldn't be a problem.
However these seem to be the cheapest alternatives.
- Antec 900 (modded) - Asus P5Q-Pro - 4GB Corsair Dominator DDR2-1066 -
- Palit GTX 260 SONIC 216SP - Core 2 Duo E8400 with Xigmatek HDT-S1283 cooler - 850watt Antec True Power Quattro -
Old March 8, 2009, 06:09 PM
WolfBane's Avatar
hey max thanks for the info bud:)
yea all i really need is that backplate to make it secure and some tim , Wouldn't you know it ncix is out of stock lol
I USE EMT ONLY
Old March 8, 2009, 09:05 PM
Bones's Avatar
This is decently priced and it preforms quite well in "normal" conditions:
Thermaltake RSI Socket 775 Aluminum CPU Cooling Fan CL-P0441 in Canada at TigerDirect.ca
I agree with Max, Arctic Cooling MX-2 is the good stuff ...
Old March 8, 2009, 09:58 PM
The MAX's Avatar
There ya go, that HSF he posted seems perfect.
Good luck!
best air cooling heat sink to use for the E8400? Gameplaywarrior Air Cooling 27 December 8, 2008 10:33 AM
what is a decent air heat sink Shadowmeph Air Cooling 13 January 8, 2008 06:46 PM
Intel 775 Heat Sink - QUICK question mattydies Water Cooling 3 June 26, 2007 06:57 PM
Modifying my CPU Heat Sink??? mattydies Water Cooling 8 June 25, 2007 09:03 PM
Heat sink and fan selection for Intel Pentium D 915... mattydies CPU's and Motherboards 6 March 17, 2007 09:36 PM
