Old March 6, 2009, 05:30 AM
What a long night....
so I ended up using a steel washer at about the same thickness of a nickel. The fan still moves!! Don't get me wrong, it helped alot but I guess I just can't get it to sit tightly. It make it very difficult to get the screws in. What a terrible design. This thing better be worth it!
I don't even want to think about lapping right now....
Old March 6, 2009, 05:45 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
I still recommend a rubber washer of about twice the thickness of a dime. I find the rubber adds a bit more grip so the heatsink doesn't move.
Old March 6, 2009, 06:05 AM
3.0charlie's Avatar
On my TRUE, I had to add a large washer (thk: 0.125") with a center hole that matched the bump on the holding bracket. This prevented the washer from moving around. But even so, the HSF did rotate slightly, so I bent the holding bracket to add even more pressure on the HSF upper surface.
Hydro-Quebec is salivating...
Old March 6, 2009, 02:11 PM
IF and when I decide to lap the cpu and hs, I'll use a rubber washer instead. I don't think I want to try bending the mount though. I may try that method if I place an order somewhere and pick up an extra set if it's available.
Old March 6, 2009, 02:35 PM
donimo's Avatar
weird, I never had this issue with mine, if anything I thought it was going to punch my cpu through the back of the mobo id was on there so tight, wonder what the difference was?
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old March 8, 2009, 02:19 PM
lowfat's Avatar
It sure is hard to install the washer without taking the mobo out.
Mael
Big Lian Li
Forever Alone
Old March 8, 2009, 03:58 PM
lowfat's Avatar
I think the washer actually mad things worse for me. Too hard to get a proper mount.
Mael
Big Lian Li
Forever Alone
Old March 9, 2009, 09:07 PM
Retro's Avatar
*cough* Noctua *cough*
Latest build:
i5 750@3800MHz 20x190@1.38125v
Noctua NH-U12P/NF-P12
4G GSkill DDR3 2000 Ripjaws
Asus P7P55D-Pro
2x EVGA GTX275 in SLI
PC P&C 750 Silencer
Cuda 500
Antec 902
W7 64 RTM
  #19 (permalink)
Old March 10, 2009, 04:59 AM
Yes, it is a pain to mount with the extra height added by the washer.
I still need a set of mushkin redlines or ascents so I can try to OC my e8400.
If I'm not satisfied with the temps, then I'll take them both out and lap them. That'll be when I change it to a rubber washer.
Maybe I'll give the Noctua's a shot down the road. I hear good things about that brand.
  #20 (permalink)
Old March 11, 2009, 06:33 PM
Retro's Avatar
I have been very pleased with mine. Not to knock Thermalright, I use many of their various heatsinks on most of my builds. As for the TRUE, I had one on my current system a year ago. I lapped it and used a steel washer on the mount which stopped it from freely moving. But I swap out cpu's often and got tired of having to fight with the TRUE's mount and bracket each time I re-installed it.
The Noctua has a flat base and a really slick mounting system that doesn't move. Much easier to remove and re-install. The TRUE was probably good for about 2C lower load temps. on my build, not a huge difference for me.
Latest build:
Asus P7P55D-Pro
PC P&C 750 Silencer
Cuda 500
Antec 902
W7 64 RTM
True 120 black phil3_66666 Buy/Sell & Trade 3 September 25, 2008 02:49 PM
True Black 120 thermalright evzonas Air Cooling 14 August 6, 2008 02:55 PM
Asus Rampage extreme and Thermalright's True bLACK 120 evzonas CPU's and Motherboards 14 August 5, 2008 02:43 PM
Thermalright TRUE Black 120 CPU Cooler Review comment thread freakgeek1337 Air Cooling 17 August 1, 2008 05:16 PM
