  #61 (permalink)
Old October 22, 2011, 01:52 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Originally Posted by Anon-Reader View Post
Instead of running the TEC at full power, the reviewer should have installed a 100watt OHMite rheostat/potentiometer and used a multi-meter to read the output voltage and current while starting the TEC off at a lower power like 1volt. This would have been a more honest method of testing its full potential.
Also I take issue with methodology and the fact that the reviewer never posted ambient temperatures and testing on a CPU is a highly variable source for heat. Instead, a consistent 100watt heat place should have been used and the temperature of the heatplate should be used to determine the effectiveness of all cooling devices.
OHMITE RKS2R0 RHEOSTAT, WIREWOUND, 2OHM, 100W
I am very interested in this unit for cooling my AMD FM1 APU based system, as I live in the south and summers here even with the central airconditioning running can cause CPU temps to drastically rise to alarming levels with out any overclocking involved. Another product I have found which I would like to see reviewed is the Ultra ChillTEC which seems like it may have some ideas that really better than the coolermaster concept.
Ultra ChillTEC 939/AM2/AM3/775/1366 Thermal Electric Overclocking CPU Cooler With Controller at TigerDirect.com
#790 - Ultra ChillTec Thermo Electric CPU Cooler - YouTube
Man that review is a bast from the past.
Guess you skipped over this page where it laid out ambient temp and the overall methodology. :/
Cooler Master V10 CPU Cooler Review
As for the 100watt heater..sure...sounds like a great idea, except for the fact that I have yet to see any PC use a 100 watt heater as a processor. It boils down to synthetic vs real world. We here prefer real world...YMMV. Honestly, CPU cooler testing by its very nature is variable. Your results will differ from someone elses. The results of the charts however will (usually) line up with your results in that X cooler vs Y cooler will net similar percentage differences in performance.
Personally I would take a Corsair H80 (or H100) over the V10 any day. IF you dont like water, there are plenty of other air based coolers which will net better results than this one. For example a Noctua D14 with 3 fans or Prolimatech Super Mega with two fans.
Cooler Master ATCS 840 Case Review Comment Thread AkG Cases 47 June 25, 2009 10:10 AM
Cooler Master Storm Sniper Case Review Thread lemonlime Cases 10 March 16, 2009 05:09 PM
Cooler Master HAF 932 Full Tower Case Review comment thread AkG Cases 11 November 21, 2008 02:50 PM
Cooler Master Hydra 8800 GPU cooler (water block?) discussion thread Misoprostol Water Cooling 9 December 7, 2007 11:27 PM
Comment Thread for Cooler Master Real Power Pro 750W Review SKYMTL Power Supplies 12 November 28, 2007 06:44 PM
