  #51 (permalink)
Old March 27, 2009, 05:22 PM
crispex's Avatar
Put it down like that stupid yellow dog from that old movie...
This site really needs an "evil" smiley, y'know?
If i don't just go with watercooling, looks like I'll have one of these.
If it ain't rocket powered, it ain't worth it.
  #52 (permalink)
Old April 19, 2009, 08:24 PM
Anyone try it with dominator ram? or know the clearence over the ram?
  #53 (permalink)
Old May 5, 2009, 08:39 PM
lowfat's Avatar
I've decided to take my V10 to the next level. I ordered a 140w 40mm TEC + PSU for it today. I'm not sure if the lil' heatsink will be able to handle the heat load. But I will try at least.
  #54 (permalink)
Old May 5, 2009, 11:11 PM
Hello,
1rst post!
I have a V-10 and I want to put beefier fans in it. I need to know how the plastic cowl is mounted? It appears in pics just to have 2 screws on one end? Also are those hex screws or a "special" tool?
Could someone who has taken this beast apart please post a brief tutorial on how to remove the cowl and fans.
I wish this was in the review like it was in the V-8.
  #55 (permalink)
Old May 6, 2009, 09:16 AM
lowfat's Avatar
They are just standard hex screws. Remove those 2, and the 6 screws that hold each of the fans in. Then pull up.
  #56 (permalink)
Old May 6, 2009, 07:38 PM
Aren't the fans just connected to the cowl? Won't they kind of fall out if I take all the screws out and then lift the cowl? Don't want to damage the cooling fins. Fans have 6 screws?
  #57 (permalink)
Old May 6, 2009, 08:26 PM
lowfat's Avatar
O ya you are right. I wasn't thinking. It is just the 2 hex screws.
  #58 (permalink)
Old May 6, 2009, 09:08 PM
MpG's Avatar
MpG MpG is offline
Didn't catch that, but might be interesting. Even if you don't run it at full voltage, there might be some potential for improvement. Maybe make that 5V rail do a little work, eh?
  #59 (permalink)
Old May 6, 2009, 09:48 PM
lowfat's Avatar
The PSU I bought is a cheap little 155W meanwell. I don't believe it has any adjustments either unfortunately.
  #60 (permalink)
Old October 22, 2011, 12:55 AM
Trial Member
Instead of running the TEC at full power, the reviewer should have installed a 100watt OHMite rheostat/potentiometer and used a multi-meter to read the output voltage and current while starting the TEC off at a lower power like 1volt. This would have been a more honest method of testing its full potential.
Also I take issue with methodology and the fact that the reviewer never posted ambient temperatures and testing on a CPU is a highly variable source for heat. Instead, a consistent 100watt heat place should have been used and the temperature of the heatplate should be used to determine the effectiveness of all cooling devices.
OHMITE RKS2R0 RHEOSTAT, WIREWOUND, 2OHM, 100W
I am very interested in this unit for cooling my AMD FM1 APU based system, as I live in the south and summers here even with the central airconditioning running can cause CPU temps to drastically rise to alarming levels with out any overclocking involved. Another product I have found which I would like to see reviewed is the Ultra ChillTEC which seems like it may have some ideas that really better than the coolermaster concept.
Ultra ChillTEC 939/AM2/AM3/775/1366 Thermal Electric Overclocking CPU Cooler With Controller at TigerDirect.com
#790 - Ultra ChillTec Thermo Electric CPU Cooler - YouTube
Cooler Master ATCS 840 Case Review Comment Thread AkG Cases 47 June 25, 2009 10:10 AM
Cooler Master Storm Sniper Case Review Thread lemonlime Cases 10 March 16, 2009 05:09 PM
Cooler Master HAF 932 Full Tower Case Review comment thread AkG Cases 11 November 21, 2008 02:50 PM
Cooler Master Hydra 8800 GPU cooler (water block?) discussion thread Misoprostol Water Cooling 9 December 7, 2007 11:27 PM
Comment Thread for Cooler Master Real Power Pro 750W Review SKYMTL Power Supplies 12 November 28, 2007 06:44 PM
