Old March 1, 2009, 07:59 PM
The MAX's Avatar
Default C2D Users...How do you have your xigmatek hdt-21283 oriented?
Hi,
I have an e8400 with a xigmatek HDT-s1283 cooler. Had it on for quite sometime now. It was my first aftermarket CPU cooler.
Recently discovered that my 2 cores are running at significantly different idle temps.
According to CPUID's Hardware monitor Core#0 usually idles at 39-40 and Core#1 at 33. That seems like a big difference and someone recently suggested I reseat the HSF.
So in my antec 900 I currently have it blowing sideways and out through the rear 120mm fan. I am going to reseat it this week and was wondering if I should change the orientation so that it blows up and out through the bigboy fan at the top.
Also, any suggestions for applyin TIM with this cooler?
I read a guide the last time, I put to thin strips on the aluminum between the heatpipes, and this spreads over the pipes. After filling the gaps of course.
Anyway, any tips would be appreciated.
I also use the thermaltake backplate mounting kit.
- Antec 900 (modded) - Asus P5Q-Pro - 4GB Corsair Dominator DDR2-1066 -
- Palit GTX 260 SONIC 216SP - Core 2 Duo E8400 with Xigmatek HDT-S1283 cooler - 850watt Antec True Power Quattro -
Old March 2, 2009, 06:17 AM
bojangles's Avatar
Shouldn't matter for your case. There is plenty of air flow Any way you orient it. It's really up to you.
Old March 2, 2009, 09:47 AM
The MAX's Avatar
I was more so thinking about how the heatpipes are oriented with respect to the two cores.
Old March 3, 2009, 07:08 AM
486's Avatar
486 486 is offline
Before you do anything check the temps under the load. If under the load (60-70) the temps of all cores are within 3-4 degrees - nothing to worry about, it just sensor error. Intel specifies that sensors are not designed to measure the idle temps.
On my Q9650 I have one hot core (+10) and one cool core (-5). Under the load hot core heats less and cool core heats more. So all cores are within 4 degrees of each other at 70 in IBT (3.6GHz).
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
Kingstone HyperX 2 x 8GB
Crucial M4 256GB + 128 GB
Sapphire Radeon HD7970
Nec Multisync LCD2690WUXI
Old March 3, 2009, 09:58 AM
lcdguy's Avatar
yup i wouldn't worry about that. I too have the xigmatek in your post on an e8400. and those temps are around what i get in my antec 300. I've done several hour gaming sessions and full speed with no issues. (by several hour, i mean 5+).
As for applying tim, the best way i have found is to run to small beads along the 2 alluminum spaces between the heat pipes. Hasn't steared me wrong yet. how ever i am using AS5 :D
Old March 7, 2009, 11:06 PM
bovine.baron's Avatar
I've got an E5200 and my cores seem to stay within five degrees of each other under full load. It's in a CM 690 so the case outake fan's on one side of the S1283 and I mounted its' fan to blow through the fins into thatone. I don't know what the aerodynamics involved are but I listen to the results; I'd say you should experiment moving your fans a little. If nothing else, it'll make you feel better. Do it for SCIENCE!
First Time mIRC users grinder Off Topic 10 October 25, 2009 06:18 AM
Quick question for all Cosmos S users werty316 Cases 22 September 21, 2008 12:25 AM
Antec 900 users... frosty Cases 5 March 26, 2008 07:24 AM
Any Clone Dvd Mobile Users? *Help Scotch Tape Mobile Computing 0 February 24, 2008 11:46 AM
