Old February 27, 2009, 05:45 PM
Default Connect case fans to the motherboard?
I was reading my motherboard manual and it suggested connecting the chassis fans to the motherboard when using multiple video cards, which I am. I can see some benefit in doing this because I can set the chassis fan profile to [standard] which automatically adjusts the fan speeds depending on the chassis temperature.
Is anyone else doing this and what are your results?
Old February 27, 2009, 05:50 PM
i always hook case fans to mobo,the upside, alarm goes if fan fails :)
and yes auto speed adjust,means quiter pc
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old February 27, 2009, 06:06 PM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
The only thing you need to be careful about doing this is the amount of juice most mobo's can provide is only enough for a couple 120mm fans (at most!)...add anymore and some will not spin. :)
If noise is a major concern I'd go w/ lower noise fans. E.G. Scythe E's or Ds or Noctua NF-p12s.
Old February 27, 2009, 06:12 PM
BT!'s Avatar
BT! BT! is offline
i have three 230mm and one 140mm fan hooked up to mine, but i dont have my HSF's hooked up to the mobo, have them directly supplied by the PSU. lol, i know, got it ass backwards..
Jake_HT's Avatar
I'm using all my motherboard fan plug ins with no problems! Easier than plugging them into an adapter to molex for sure.
Use the CPU fans on the mobo, and then case fans that don't matter as much just plug them into PSU, that way you'll get a warning if a CPU fan fails
http://jakeht.deviantart.com/
Old February 27, 2009, 06:17 PM
use this,and hook up plenty of fans safely NCIX.com - Buy Bitspower X-STATION POWER-EXTENSION I - Male Version 4PIN Molex to Power Distribution Board - Green - BP10500 In Canada.
Old February 27, 2009, 08:43 PM
My motherboard manual states:
CPU, chassis power fan connectors support fans" - "for a total of 7 A (84 W max.) at + 12V.
So I think that I've got a ton of headroom before reaching those maximums; considering the average 120mm fan draws 2 W and .3 A.
There are a total of 5 fan connectors on my motherboard, 3 of which are chassis fan connectors that automatically adjust the fans speeds, depending on the chassis temperature. I do have my CPU fan hooked up to the motherboard and it's working as advertised.
So I was thinking of hooking up my front 230mm inlet fan, top 230mm exhaust fan and rear 140mm exhaust fan on my HAF to the motherboard. That will leave my 230mm side inlet fan and lower 120mm inlet fan connected to my PSU.
As is, it's not all that noisy but I can see a couple of benefits in using those 3 motherboard chassis fan connectors.
Old February 27, 2009, 10:01 PM
JD JD is online now
I'd be careful with those 230mm fans and auto speed control...
Chances are the motherboard might not give it enough power so they might not even spin up. Test it and see though.
Old February 28, 2009, 12:32 AM
I just finished hooking up my front 230mm inlet fan, top 230mm exhaust fan and the rear 140mm exhaust fan to my motherboard, enabled the CPU and chassis fan controls, set their profiles to standard and booted into Vista.
WOW, I now have what I consider a silent PC, so silent in fact that at first I was positive that the fans couldn't be working. Quick glance at the front fan, it's spinning, quickly open up speedfan, all the fans are working but I can't hear them.
Ok but do they function properly? Open up realtemp, cpuz and do a quick run of Prime95. The temps are ~ the same as when I didn't have them hooked up to the motherboard and now I can hear the fans but their almost dead silent, when compared to when I had them hooked up to the PSU.
Stock:
While running Prime95
Needless to say I'll keep a keen eye on this setup but I'm completely flabbergasted at the lack of noise. I'd be really interested in seeing if BT can change his setup and let me know the results.
Where Can I Buy Dust Filters For Case Fans...? mlauzon Air Cooling 11 January 19, 2009 10:49 AM
TJ09 Case n Additional 120 mm Fans rjbarker Cases 1 November 11, 2008 10:04 AM
Case Fans? chouchou Air Cooling 3 October 24, 2008 06:49 PM
suggestions for case fans..... rob123 Air Cooling 18 August 13, 2008 08:19 PM
Antec 900 Stock Case Fans grantman77 Air Cooling 4 June 9, 2008 12:41 PM
