Originally Posted by element291 I have no problems with the pushpins, easy on and off. The vendetta is a 20 second install. Just get a flat straightedge (metal, or something strong) then position it under the fan, ontop the pushpin, and push down. Easy as pie. I couldnt find my metal ruler so i used a saw blade that came with my saws all. |
Sounds like it either goes on easy... or its the most difficult thing in the world. It honestly took me an hour to get it on in the first place. I had to apply a large amount of force, I was worried I would break my motherboard. By the end of it, my fingers were killing me, and I was exhausted.
Even after all that, Im not confident that it will stay on. There were a few times where I thought I had it and it would pop off again as I was installing the other components.
