Old February 17, 2009, 07:19 AM
CanadaRox's Avatar
If you are interested in doing the teaming, look at getting the three blade deltas as the blades spin opposite direction as nearly every other fan, and is the only 38mm fan I know of that does this. Vapor at XS did some testing with a low speed 3-blade delta, and a Sharkloon fan with similar CFM rating. He found that he got a slightly higher CFM (about 10CFM extra), but got a huge improve in pressure which made it very good for on a radiator, especially a restrictive one like a Black Ice GTX. Overall, I wouldn't bother with it, unless you are doing push/pull on a rad or heatsink because the increase in preformance for open air isn't much.
Project: Black and White
Old February 17, 2009, 09:41 AM
486's Avatar
486 486 is offline
Well, I was thinking of creating a wind tunnel with Vendetta 2 in the middle. Vendetta's fan (intake), case fan (discharge) and middle fan attached to case fan on 50 mm standoffs (so it is 15 mm from the west end of vendetta). I was even thinking of making some kind of shroud between middle fan and discharge case fan. Oh, well, I can simply put CPU to stock 3GHz :)
Fractal Design R5 + Seasonic X-660 650W
Asus X299 TUF Mark 2 + Intel i7-7800X + G.Skill Ripjaws V 3200 8GB x 4
Samsung 950 Pro 512GB + Samsung 850 Pro 512GB + HGST 5400RPM 2TB
Evga GTX 1080 FTW 8GB + BenQ BL3201PH 4K 32"
Old February 17, 2009, 04:33 PM
CanadaRox's Avatar
Your best bet would probably be just adding a second fan on the Vendetta pulling air through. Then just have that fan pointing towards the exhaust. And there is always the option to just upgrade your current fans to something with more airflow.
Internet teaming timbruun CPU's and Motherboards 16 September 27, 2008 09:32 PM
