Old February 14, 2009, 01:46 PM
486's Avatar
486 486 is offline
Default Xigmatek ACK-7361 Crossbow kit Compatibility warning
Xigmatek ACK-7361 Crossbow kit and ASUS P5Q-E Motherboard are not fully compatible. Two of the capacitors contacts are TOUCHING metal backplate. Good thing I did not start the PC. I got to file down the backplate to make backplate arms narrow.
Please be careful installing this product (or similar) with Xigmatek/OCZ cooler:
XIGMATEK
Previous version of the kit had backplate similar to Thermalright one. No problems there, as arms were narrow.
Fractal Design R5 + Seasonic X-660 650W
Asus X299 TUF Mark 2 + Intel i7-7800X + G.Skill Ripjaws V 3200 8GB x 4
Samsung 950 Pro 512GB + Samsung 850 Pro 512GB + HGST 5400RPM 2TB
Evga GTX 1080 FTW 8GB + BenQ BL3201PH 4K 32"
Old February 14, 2009, 02:14 PM
sswilson's Avatar
Any chance you can get a picture of the problem?
Old February 14, 2009, 03:02 PM
Eagle Eye's Avatar
Hey SS if its okay with 486 modify the title to include "Xigmatek ACK-7361 Crossbow kit"
Old February 15, 2009, 11:26 AM
486's Avatar
486 486 is offline
Default Unfortunately I did not take pictures
I am OK with title change. Unfortunately I did not take pictures.
Old February 15, 2009, 11:27 AM
sswilson's Avatar
Done.
Potential Warning Regarding HD3870X2 Cooler Compatibility SKYMTL Video Cards 8 April 25, 2009 07:56 AM
Xigmatek crossbow plate is slightly twisted 486 Air Cooling 0 February 11, 2009 09:41 AM
Steam hijack warning CasheKicker O/S's, Drivers & General Software 4 January 26, 2009 05:05 AM
Dry Ice [Warning 56k] CanadaRox Case Mods, Worklog & Gallery 27 March 14, 2008 08:51 PM
MDF Case build! 25K warning! chibi_man Case Mods, Worklog & Gallery 62 November 19, 2007 11:18 AM
