Old February 12, 2009, 01:39 AM
Default How often do I have to replace CPU Heatsink, and Fans?
I run my PC nearly 24/7.
In I have two Noctua NF12 running, one for heatsink and one for cooling, and Noctua NH U12P 1366 heatsink. The average temperature for Cores is about 47C with the ambient temp 39C. Since I use Antec P182, it doesn't let the heat out well. I plan to get more Noctua fans when the price comes down.
Anyway, what's the average life span for a CPU heatsink and 120MM fan assuming that the computer is running 24/7.
Thank you.
Old February 12, 2009, 04:42 AM
1Tanker's Avatar
Thank you.
There isn't really any limit on HS's...that i know of. I say "that i know of", because heatpipe HS's haven't really been popular for that long...so i can't say for sure if the gas inside eventually weakens or evaporates as in a cars' A/C system. Fins, bases, and everything else should outlast most any processor. Fans... no set time period(i've never "worn-out", or killed a HS..just the fans). The quoted MTBF from manufacturers is pretty meaningless, so the only true indicator of when it's time to change a fan is, if/when it starts rattling, squeeling, ticking, smoking , or seizes. If you're worried....for your own peace-of-mind, replace the fans between every year-two years, and hopefully you'll avoid a CPU-stressing fan death. It's probably worth spending $20-$30/year on fans, to keep your prized CPU purring along at a decent temperature. Also, realize, that you can buy fans that either arrive(by courrier/mail) DOA..or can and will die way before their time. It's always wise to have a few spare fans(of the proper size) kicking around just in case a fan unexpectedly kicks-the-bucket. Good 120mm ball-bearing fans can last 5+years...np. Oh.. and keeping them clean, by blowing or brushing the dust off/out of them can extend their lifespan. Using low static-pressure fans in highly resistive situations, can kill a fan in a matter of months... so use the proper fan, for the proper application.
Sorry for the novel. GL
Old February 12, 2009, 05:21 AM
sswilson's Avatar
Only thing I can add to that is to periodically brush/clean out the fins of your HSF as well.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old February 12, 2009, 05:38 AM
1Tanker's Avatar
It's in my post.
Old February 12, 2009, 05:57 AM
Eagle Eye's Avatar
Its the stuff between your cpu and heatsink (Thermal Interface material) that should be replaced every 12-24 months depending on the type.
Tanker has got it covered on all the rest.
EE
Old February 12, 2009, 06:02 AM
ipaine's Avatar
Really? I guess I should start replacing those fans then, I thought that the smoke created a nice visual effect and allowed one to see how well their airflow worked.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old February 12, 2009, 07:53 AM
1Tanker's Avatar
Well, yes...it does make for a nice show, and can help with determining airflow paths ...but you gotta enjoy it quickly, because i guarantee you won't find smoke rolling out of your CPU as amusing and helpful.
Old February 12, 2009, 08:48 AM
486's Avatar
486 486 is offline
Default 24/7/365
In case of 24/7/365 operation I would:
1. Install air filters on all entries in the case.
2. Clean filters every 6 months
3. Replace fans every 2 years.
Intel Q9650
Sapphire Radeon HD7970
Mushkin Redline 4 x 2GB
Asus P5Q-E
Nec Multisync LCD2690WUXI
Old February 12, 2009, 12:48 PM
JD JD is online now
I see no reason to replace fans if you've bought high-quality ones like the Noctuas the OP is running.
[WTB] LGA 478 Heatsink Jon_di2 Buy/Sell & Trade 2 February 4, 2009 07:46 AM
Replace stock white pads with Sekisui? werty316 Video Cards 1 December 6, 2008 01:28 PM
Intel to Launch Q9650 in Q3 to Replace QX9650 Hardware Canucks Press Releases & Tech News 15 August 12, 2008 06:35 PM
Backplate pad pulled off-how to replace it magictorch Troubleshooting 20 July 20, 2008 09:36 PM
Microsoft Wants to Replace Vista in Two Years. Babrbarossa Press Releases & Tech News 0 February 14, 2007 07:42 AM
