Old February 11, 2009, 07:53 PM
Default Xigmatek ACK-i7361 Bracket Installation (few questions!)
Hi, i have purchased Xigmatek Retention Bracket to install my Ocz Vendetta 2 cooler on my Q9650.
My question is : in the box i have separate double sided sticker that one side should stick on the bracket and the other side should stick on the back of the mother board when installing the bracket.
But i heard once it's stiked on the MB it's VERY HARD to remove, so does it cause problem if i just do not remove the paper that protect the sticky part that should stick on my MB.
That way it will not stick onto my MB.
Second Question, what happen if i just do not put the double sided sticker at all...?
If the metal bracket touche the back of the MB i will shock it ?
If so, it really a necessity to at least stick it on the bracket and this sticker is the only thing that prevent the MB to being skocked? (i think it's not very tick) there is really no risk of damaging the MB ?
Thanks and sorry for bad english!
Old February 11, 2009, 08:07 PM
stoanee's Avatar
Just stick one side to bracket and leave paper or plastic on other side so it does not stick to mobo....it will work fine that way.
heatware
Old February 11, 2009, 08:36 PM
486's Avatar
486 486 is offline
You may remove just a small piece of paper, so it still sticks to MB, but it should not be that hard to remove using hairdryer to heat up the glue.
Is your backplate is perfectly flat? I mean, if you put it on the desk surface, does it rock as two ends are slightly higher than other two?
Fractal Design R5 + Seasonic X-660 650W
Asus X299 TUF Mark 2 + Intel i7-7800X + G.Skill Ripjaws V 3200 8GB x 4
Samsung 950 Pro 512GB + Samsung 850 Pro 512GB + HGST 5400RPM 2TB
Evga GTX 1080 FTW 8GB + BenQ BL3201PH 4K 32"
Old February 12, 2009, 03:41 PM
I just checked the Backplate it look almost perfectly flat... it rock a very very little bit but it's almost nothing.
What happen if it's not perfectly flat ? there is risk of short the MB ?
Need help with 478 bracket barts Air Cooling 3 December 1, 2008 03:23 PM
Help for Asus P5Q installation MrDeodorant Troubleshooting 3 November 14, 2008 06:49 PM
LF: PSU Bracket enaberif Buy/Sell & Trade 0 August 22, 2008 06:59 PM
Help with 2900xt installation SirenOfDarkness Video Cards 15 September 9, 2007 01:40 AM
Installation of Windows XP enaberif O/S's, Drivers & General Software 3 January 24, 2007 11:54 PM
