Stock 120mm fan in Antec Sonata III failed
A few days ago, My system froze, then a day later it blue screened in vista....
I figured it was about time to take a look inside the case, first off the cpu cooler fan was running well, but the top heatsink fins were blocked with dust.... I did a cleanup with compressed air, made a heck of a mess but that sorted out that issue....
But...
I noticed the rear 120mm Antec tri-speed fan was dead, would not spin at all, so I removed the sticker, removed the plastic ring retainer, took fan out if its sleeve cleaned out all the dust and cleaned the shaft the fan spins on... reassembled the fan, and it now spins freely.... and at a high speed if set to max, the big issue is it now makes an irritating sound, that comes and goes but never goes away... So I figure its time to toss the fan.... I replaced it with an old 80mm delta fan, that sucker is very high output, and is as loud as it is fast....VERY VERY VERY LOUD, I will keep it in my case untill I can line up a (cheap but good) replacement, if I can get one. I thought the antec fans were supposed to be good, now I'm not sure, the fans had it in less then 2 years service. Do you guys know of some good cheap LED 120mm fan replacements that have good air flow, and are less prone to seizing up? (I'm not sure if there is such a thing as a non-seizing case fan but if there is I want one...
__________________ Intel Core i5-750 2.66Ghz @ 4Ghz, ASUS P7P55D-E Pro, 4GB G.SKILL Ripjaws cas7, WDC 1Tb WD1001FALS, WDC 640Gb WD6400AAKS, OCZ Vertex 2 Extended Sandforce 60GB, GIGABYTE Radeon HD 7950 3GB 384-bit GDDR5, Corsair Hydro H70, LG GH24NS50 DVD 24x Burner, Antec Eleven Hundred, Antec TruePower New TP-750 750W, Microsoft Windows 7 Ultimate x64 http://i571.photobucket.com/albums/s...osmond/1-1.jpg http://i571.photobucket.com/albums/s...benchmarks.jpg |
