Old February 11, 2009, 02:27 PM
Phobia's Avatar
Default Low profile heatink
Can anyone recommend a good low profile heatink? I bought the nmedia 1000 case, and am going to need a heatsink to fit that case. It will be an intel processor. I haven't chosen a cpu for it yet. It depends on the heatsink. If it can handle a quad, then i will buy a q6600. If it can't, well, i'm not sure what i'll buy instead.
(whitty saying to be plagiarized at a later date)
Old February 11, 2009, 02:40 PM
FiXT's Avatar
Hall of Fame
Depends on what your going to be cooling.
Something like this unit should do the trick and is fairly cheap depending on where you buy or if you PM:
Scythe Shuriken 3 Heatpipe Low Profile HTPC CPU Heatsink - TechWiki
Old February 12, 2009, 06:08 PM
Phobia's Avatar
awsome, thanks fixt
Old February 12, 2009, 06:12 PM
3.0charlie's Avatar
Thermalright SI-128.
Old February 12, 2009, 06:24 PM
Phobia's Avatar
I was looking at that, but I'm not sure if it'll fit in the nmedia 1000 with a fan on.
Old February 12, 2009, 06:30 PM
3.0charlie's Avatar
Plenty of clearance in my 932B with a 120 on top.
Old February 12, 2009, 06:38 PM
Phobia's Avatar
cool. Thanks. Now i'm not sure which one to get.. the thermal right is 50$, while the scythe is 25$. Does the performance justify the extra cost?
Old February 12, 2009, 06:39 PM
3.0charlie's Avatar
No idea, never owned the Scythe.
Old February 12, 2009, 06:40 PM
"Quote This..."
Hurry up and decide so you can buy my Chip :)
Old February 12, 2009, 07:02 PM
Phobia's Avatar
oh, hahaha. Now that there are heatsinks that are adequate out there, i will buy it. I assumed that you had sold it, as you didn't PM me back :P
EDIT: I looked at the dimensions, and the case itself is about 14 cm high. The thermalright heatsink is 10 cm high without a fan, and a fan adds about 2.5 cm. That leaves me with 1.5 cm .. so, I THINK i should be good.
Profile with Dual Monitors sircuster Display Units 0 January 23, 2009 05:24 PM
Low Profile CPU Heatsinks phil3_66666 Air Cooling 0 January 23, 2009 09:27 AM
Cod 5 saving profile question. Patriote Gaming 7 November 30, 2008 03:32 PM
ThermalRight AXP-140 Low Profile Heatsink Eagle Eye Air Cooling 5 November 22, 2008 03:07 AM
WTB Low Profile Ram Sinks arekieh Buy/Sell & Trade 6 November 8, 2008 12:05 PM
