Old February 11, 2009, 09:41 AM
486's Avatar
486 486 is offline
Default Xigmatek crossbow plate is slightly twisted
Xigmatek crossbow plate is slightly twisted. On even surface it rocks as two opposite ends are slightly higher than the other two (1-1.5 mm).
It should not be a problem, right?
I'd recon under the spring load it will take shape however tight I will screw in the bolts (I tried to untwist it with hands, it springs back to twisted shape).
How tight the screws should go in? Hand tight? Little wrench supplied tight?
It is my first backplate/screw mount. Trying to get the thing right the first time.
Fractal Design R5 + Seasonic X-660 650W
Asus X299 TUF Mark 2 + Intel i7-7800X + G.Skill Ripjaws V 3200 8GB x 4
Samsung 950 Pro 512GB + Samsung 850 Pro 512GB + HGST 5400RPM 2TB
Evga GTX 1080 FTW 8GB + BenQ BL3201PH 4K 32"
Antec 900 (painted/slightly modded/and with decent cable management) + Introduction The MAX Case Mods, Worklog & Gallery 20 July 29, 2009 04:18 PM
Why dont benchmarks include slightly older hardware? muse108dc Video Cards 11 December 19, 2008 01:03 PM
CPU backing plate question kruzn4evr O/S's, Drivers & General Software 9 November 14, 2008 04:17 PM
Options on a deal gone slightly bad Eagle Eye Off Topic 16 May 22, 2008 08:51 PM
Copper Plate w/ Ultra 120 enaberif Overclocking, Tweaking and Benchmarking 6 February 5, 2008 06:36 PM
