Old February 11, 2009, 12:14 AM
Default best heatsink for Q9550
n00b to oc'ing and i'm looking to oc my Q9550 to the 4.0ghz range. can anyone reccomend the best aftermarket h.s please
How much better is w.c over air?
thanks
Old February 11, 2009, 03:11 AM
Eagle Eye's Avatar
http://www.thermalright.com/new_a_pa...ler_775rt.html
EE
Old February 11, 2009, 05:48 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Water cooling can put you back a fair amount if you want significantly more overclocking room than air cooling. Personally though I would think about two options: the Xigmatek HDT-S1283 or if you want to get your feet wet without going to extremes, grab the CoolIT Domino.
Old February 11, 2009, 05:53 AM
Eagle Eye's Avatar
http://www.ncix.com/products/index.p...e=Coolit%20Inc
beDirecT.ca
EE
Old February 11, 2009, 06:11 AM
Soultribunal's Avatar
Or if you really want to go to extremes , but still not do your own custom loop, get the Coolit Freezone Elite MTEC.
That thing had an awsome review here at HWC, and is a true best dealing with Thermals.
ST
Old February 11, 2009, 08:30 AM
486's Avatar
486 486 is offline
Xigmatek only with crossbow. Learned the hard way. Fan mount on Xigmatek is ridiculous. Get Extreme.
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
Kingstone HyperX 2 x 8GB
Crucial M4 256GB + 128 GB
Sapphire Radeon HD7970
Nec Multisync LCD2690WUXI
Old February 11, 2009, 10:17 AM
Phobia's Avatar
the TRUE would be good. Get some noctua's and you'd be gold. Unless you want to Water cool, which would be awsome, but a lot more expensive
(whitty saying to be plagiarized at a later date)
Old February 11, 2009, 11:04 AM
The MAX's Avatar
I have the Xigmatek, and I like it.
Used a thermaltake bolt thru kit.
- Antec 900 (modded) - Asus P5Q-Pro - 4GB Corsair Dominator DDR2-1066 -
- Palit GTX 260 SONIC 216SP - Core 2 Duo E8400 with Xigmatek HDT-S1283 cooler - 850watt Antec True Power Quattro -
Old February 11, 2009, 11:16 AM
Jake_HT's Avatar
I'm vouching for the Thermalright Ultra Extreme 120, great alternative to water. Keeps my i7 cool easily! Strap 2 fans on there and it cools very well.
http://jakeht.deviantart.com/
Old February 11, 2009, 02:25 PM
geokilla's Avatar
OCZ Vendetta 2. Best bang for buck HSF. Just be sure to get the retention bracket if you hate dealing with push pins.
Q9550 Temps Zeroman_IR CPU's and Motherboards 14 April 20, 2009 03:11 AM
500w and q9550 mailaw Power Supplies 0 December 5, 2008 03:59 PM
FS: Q9550 Used less than 1 month! Nademon Buy/Sell & Trade 12 October 20, 2008 09:35 PM
OCing q9550 on stock heatsink? ricknash61 Overclocking, Tweaking and Benchmarking 2 September 3, 2008 06:21 PM
