Old February 9, 2009, 09:32 PM
486's Avatar
486 486 is offline
Default prime95 without cooler!
Damn pushpins, Vendetta2 fell off while PC was in Prime95. Good thing I was in front of PC. Cores went to 90s, then one core shot up to 100 degreeC, I rapidly killed prime95, shut down PC. 2 top pushpins unset, cooler was hanging on bottom two in tower case.
I suppose cpu was throttling like hell. I am surprised it did not crash, BSOD or anything. I actually orderly shut down Vista. Those 45 nm quads are real monsters.
I hope no permanent damage was done to cpu itself.
Fractal Design R5 + Seasonic X-660 650W
Asus X299 TUF Mark 2 + Intel i7-7800X + G.Skill Ripjaws V 3200 8GB x 4
Samsung 950 Pro 512GB + Samsung 850 Pro 512GB + HGST 5400RPM 2TB
Evga GTX 1080 FTW 8GB + BenQ BL3201PH 4K 32"
Old February 9, 2009, 10:08 PM
sswilson's Avatar
hehehe....
Don't try this at home kids!!! (These chips are pretty resillient. I once fried an AMD 1G Thunderbird by thinking that the HSF would be fine unsecured so long as it was making contact with the cpu..... took all of 3 seconds to fry the chip :) ).
Have you got it back up and running properly?
Old February 9, 2009, 10:58 PM
LCB001's Avatar
Folding Captain
When you are using the pushpins on the Vendetta2 make sure you hear a faint click-click, if you don't they are not all the way in...
Folding For Team 54196
Old February 9, 2009, 11:11 PM
CTA's Avatar
CTA CTA is offline
hahaha... pushpins really suck... my brother's boss's computer dont have stock cooler for many weeks... (last time i was fixing and installing software and hardware something)... later i found out that cooler didn't installed properly... i dont know how it falls... so i am amazing how intel e6200 (i think) didnt fry or damage...
anyway... i suggest you to buy Thermalright LGA1366 BOLT-THRU Kit for about 10cdn...
Old February 10, 2009, 02:47 AM
Eagle Eye's Avatar
CTA you linked the wrong one
This will do both sockets NCIX.com - Buy Xigmatek ACK-I7361 Crossbow Mounting Kit LGA1336 775 for HDT-S963 HDT-S1283 RS-S1283 - ACK-I7361 In Canada..
If you can find this I'd be shocked OCZ Technology | Products | Cooling Products | OCZ Force LGA 775 Retention Brackets - Vendetta Series
EE
Old February 10, 2009, 03:12 AM
Pushpins do not suck; I'm really tired of people saying this.
The problem comes into play when people don't know how to properly use them and that manufacturers use large heatsinks with pushpins.
Stock Intel coolers were perfectly fine with them.
Also a lot of time its PEBKAC errors and not realizing they haven't actually locked the pins into place before moving on or locking pins in a criss-cross pattern which if they read the Intel instructions would tell you ;)
Old February 10, 2009, 03:33 AM
Eagle Eye's Avatar
PEBKAC, the first i have seen or heard of that acronym and quite funny. I can think of about a gazillions situations here that would of been very appropriate.
EE
Old February 10, 2009, 06:06 AM
Soultribunal's Avatar
Although Pushpins if used properly are somewhat reliable in their function, I'd suggest like the others have here to get the bolt-thru kit and call it a day with that.
Quads can run hotter than hell sometimes, hopefully with luck nothing got cooked in the whole process.
ST
www.realhardwarereviews.com
Old February 10, 2009, 09:01 AM
Eldonko's Avatar
Hardware Canucks Reviewer
I never thought I would hear someone passionately defend pushpins. Enaberif pushpins suck and no matter if you think it is user error or not I hate them. Hmm a crap piece of plastic or metal bolt which is easier and more reliable..
Old February 10, 2009, 09:32 AM
Andy's Avatar
I use to defend pushpins, because if they are seated properly they do the job just fine. But, then I got my Noctua cooler, and I will never go back to pushpins. They really do suck compared to the ease of a bolt through kit. Not to mention, knowing your cooler isn't going to go anywhere.
SAGER 5165 - Matte Screen (1920x1080) - i7-2630QM - nVidia 555M - 8Gb DDR3 - 120Gb Corsair Force GT SSD - 500Gb Momentus XT - Intel® 6300
Prime95 Error Vegaslife Overclocking, Tweaking and Benchmarking 6 January 19, 2009 10:55 AM
Need some help with prime95 Gameplaywarrior O/S's, Drivers & General Software 2 November 29, 2008 12:16 PM
Prime95 and other stress tests Dwayne Overclocking, Tweaking and Benchmarking 22 September 7, 2008 07:05 PM
HWMonitor w Prime95 Running rjbarker Overclocking, Tweaking and Benchmarking 0 April 3, 2008 08:15 PM
Prime95 v2.51 enaberif Overclocking, Tweaking and Benchmarking 6 July 25, 2007 08:34 PM
