Old February 10, 2009, 09:35 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Exactly. Pushpins work ok if you install them properly and dont end up bending the hell out of em. But the bolt thru kit is much easier and you know it is not going to pop off.
Old February 10, 2009, 09:54 AM
CTA's Avatar
CTA CTA is offline
eagle eyes.. my bad... sorry...
and yeah what everyone says about it...
Old February 10, 2009, 10:44 AM
its not that pushpins DONT work, its the fact that theyre a pain to install. THATS why there is so much user error with them, something simple and great like the bolt thru reduces user error easily, push pins are out dated and useless imo.
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
Old February 10, 2009, 04:14 PM
sswilson's Avatar
hrmmmmm....
No response from the OP.......
I hope his proc survived the ordeal.
Old February 10, 2009, 06:50 PM
486's Avatar
486 486 is offline
Well, I have installed stock cooler. It runs, it primes, it shines.
Looks like instead of inventing very simple and reliable cooler installation lock, Intel spent untold millions designing chips that don't die without heatsink :)
I mean, I was scared to death having 400CAD CPU go up in smokes. I hope it is not going to have some long term effect on it, it did not burn one of those quadrillion of transistors in two dies.
Fractal Design R5 + Seasonic X-660 650W
Asus X299 TUF Mark 2 + Intel i7-7800X + G.Skill Ripjaws V 3200 8GB x 4
Samsung 950 Pro 512GB + Samsung 850 Pro 512GB + HGST 5400RPM 2TB
Evga GTX 1080 FTW 8GB + BenQ BL3201PH 4K 32"
Old February 10, 2009, 06:51 PM
486's Avatar
486 486 is offline
I am curious, did anyone had their quad core fried when cooler fell off?
Old February 10, 2009, 08:02 PM
sswilson's Avatar
Good to hear that it seems to be working fine. I've only ever have a single C2D chip die on me, and that was due to WC coolant flowing down the traces on the back of the motherboard... I suspect it shorted out to a voltage much higher than normal vcore. (The board was fine... the chip was dead).
Old February 11, 2009, 07:06 AM
CanadaRox's Avatar
When the guy who made realtemp was doing his testing to find the Tjmax of the 45nm quads he ran his E8400 without a heatsink and nothing more than an 80mm fan on it, and IIRC his proc was still running fine. Nearly all of the procs/mobo's will shutdown at a critical temperature to prevent damage so I think your CPU is safe.
Project: Black and White
  #19 (permalink)
Old February 11, 2009, 09:32 AM
486's Avatar
486 486 is offline
Thanks. I was kind of surprised to see 100 degree in Real Temp. That's Tjmax, chip supposed to be shut down, not priming under heavy throttle.
  #20 (permalink)
Old February 11, 2009, 11:33 AM
Phobia's Avatar
Thats good to hear it didn't die. In the summer, one of the pc's in our house (p4) was reading 102 degrees. I couldn't figure out why it was running so hot. My guess is that I was using the wrong monitoring program that wasn't meant for p4s. Thats the only thing I can think of, as the heatsink was still on!
And about the debate about pushpins, I would MUCH rather have a bolt thru kit. I was installing a pushpin after market heatsink on a computer i built for someone, and it did not want to stay on. I'd hear the clicks, then i'd move the motherboard, and the top would come undone.
(whitty saying to be plagiarized at a later date)
Prime95 Error Vegaslife Overclocking, Tweaking and Benchmarking 6 January 19, 2009 10:55 AM
Need some help with prime95 Gameplaywarrior O/S's, Drivers & General Software 2 November 29, 2008 12:16 PM
Prime95 and other stress tests Dwayne Overclocking, Tweaking and Benchmarking 22 September 7, 2008 07:05 PM
HWMonitor w Prime95 Running rjbarker Overclocking, Tweaking and Benchmarking 0 April 3, 2008 08:15 PM
Prime95 v2.51 enaberif Overclocking, Tweaking and Benchmarking 6 July 25, 2007 08:34 PM
