Thank You Very Much for the suggestions SoulTribunal and CMetaphor. I guess fan controller is the only way. I actually considered this to be a problem mainly because nobody seemed to complain about the fan speeds in the reviews, so I assumed that somehow the fans are supposed to turn automatically not with the highest settings. I actually just changed the fans with another fan an it turns fast too, as you guys said probably there's no voltage regulator for my A8N-E. It is scary though that hitting the pc could lower the fan speeds somewhat
. Thank Again guys.
