Old January 28, 2009, 08:21 PM
The MAX's Avatar
Default Aftermarket chipset cooling for P5Q-Pro?
Hi,
I have the P5Q-Pro, currently with a e8400, hoping to buy a core 2 quad later this year and OC'ing it.
I was wondering about chipset cooling. I have great air-cooling for case/cpu/vid card, but I still have the stock cooling on this board. I'm fine with it for now, but I'm just curious to see if anyone has aftermarket chipset/mosfet cooling on this board.
I only ask becasue the NB cooler is attatched to the mosfet cooler via heatpipe, and I'd like to see what other people have set up on their P5Q-Pros.
Thanks.
- Antec 900 (modded) - Asus P5Q-Pro - 4GB Corsair Dominator DDR2-1066 -
- Palit GTX 260 SONIC 216SP - Core 2 Duo E8400 with Xigmatek HDT-S1283 cooler - 850watt Antec True Power Quattro -
Old January 28, 2009, 08:23 PM
Most people leave it stock.
Its a good design on the board and doesn't really need any help.
Old January 28, 2009, 09:25 PM
sswilson's Avatar
Yeah, I left it at stock, but that's on an open test bed with good active cooling.
I'm running a Q6600 @ 3.74 w/ FSB of 416 folding 24/7 without any chipset heat issues. I was all primed to drop some enzotech heatsinks on trouble spots, but under 24/7 full load there aren't any areas of concern.
Old January 29, 2009, 06:24 PM
Retro's Avatar
Originally Posted by The MAX View Post
Hi,
Thanks.
On my P5Q-Pro, I removed the stock heatpipe assembly and cleaned off the factory chewing gum from the chipsets. I fitted Thermalright Hr-09S and Hr-09U Mosfet sinks with #4 nuts and bolts using plastic washers for insulation. (Push-pins suck.) On the nb, I bolted on a Thermalright HR-05 SLI heatsink. I left the stock sb sink on after applying MX2 and bolting it on as well, although I intend to replace it with an Enzotech copper chipset sink.
Although there are those who would say the stock heatpipe assembly is fine, I like the additional cooling provided by these heatsinks. I run my E8600 at 4400MHz at 1.4000 volts 24/7 and have no heat issues. The aftermarket heatsinks certainly do help.
Latest build:
i5 750@3800MHz 20x190@1.38125v
Noctua NH-U12P/NF-P12
4G GSkill DDR3 2000 Ripjaws
Asus P7P55D-Pro
2x EVGA GTX275 in SLI
PC P&C 750 Silencer
Cuda 500
Antec 902
W7 64 RTM
Old January 29, 2009, 09:20 PM
Silvgearx's Avatar
The p5q pro is quite well built, the easiest way to cool it is to buy an antec spotcool, but it cost $15 and quite loud.
The cheapest solution is to use some tape and stick a 40mm fan in there it does the job and its cheap. i ripped the 40mm from a external ide dvd drive
another way is to spend like $30 and get one of those thermalright mosfet coolers, which you have to remove the mobo, the heat sink, reapplied TIM. Which is a lot of work
Old January 29, 2009, 10:23 PM
The MAX's Avatar
I have decent cooling (antec 900 with good cable management + vga and cpu aftermarket coolers) and I'm currently not OCed so its not a big deal I was just curious
Do you have a pic of your mobo with the aftermarket coolers?
I'm curious now!
Old January 30, 2009, 12:03 AM
Retro's Avatar
I'm curious now!
No, but I can arrange to take a shot, upload it to Photobucket and then post it here. I'll try to post by tomorrow, after work (blech).
Latest build:
Asus P7P55D-Pro
PC P&C 750 Silencer
Cuda 500
Antec 902
W7 64 RTM
Old January 30, 2009, 08:46 AM
The MAX's Avatar
Old January 30, 2009, 08:53 PM
Retro's Avatar
I'm curious now!
Here you go. Pardon my crappy cabling, it's still a work in progress.
Not the best photo, the top HR-09 is hidden by my Noctua cpu sink. You can see the top of the other HR-09 to the left of the Noctua and the HR-05SLI on the nb just above the video card. I am going to be stuffing an HR-03GTX cooler for the GTX280 in there as well
Latest build:
Asus P7P55D-Pro
PC P&C 750 Silencer
Cuda 500
Antec 902
W7 64 RTM
Air Cooling your Chipset Soultribunal Air Cooling 10 January 28, 2009 04:32 PM
Safe I7 920 OC Without Aftermarket HSF rjbarker Overclocking, Tweaking and Benchmarking 10 January 22, 2009 07:35 AM
LF: Aftermarket GPU Cooler werty316 Buy/Sell & Trade 2 September 23, 2008 03:39 PM
WTB:8800GTX aftermarket cooler magictorch Buy/Sell & Trade 0 January 28, 2008 09:47 AM
Best aftermarket cooling for 8800GT. abs0Lut Video Cards 12 December 7, 2007 08:18 PM
