Originally Posted by Soultribunal First, Good review as always. It was the quality and the depths of Hardware reviews that brought me here in the first place.
I think the TRUE is the pinnacle of Towercoolers. It is the Technology stretched to its limits (with some small exceptions). What Thermalright has to do now, is make the base and heatpipes out of High grade Silver if they want to increase the cooling power of this beast.
The only thing, is as stated getting this thing to fit in some builds could prove challanging...all in all its a good design (I was shocked it came with a fan!).
Regards,
ST |
I agree, but...
If you think ThermalRight heatsinks are expensive now can imagine how expensive they would be if they used silver. I think it would be cheaper just to go water or some other form of extreme cooling.
Thermalright is getting mixed reviews about the fans so I was told.
Originally Posted by bojangles Well I really don't know what to say...I mean, I think we've hit maximum performance out of air cooling. I know that 3.9 GHz is a fairly high OC on an i7 (and these do run hot), but it's still a fairly high temperature when its in the 70s. IMHO, I don't like running anything over 65. Even push/pull configuration doesn't really do any good when temps are that high.
I think I'll invest into the i7 architecture when the 32nm node comes out.
Awesome review though! HWC > all. |
The way I see it Bojangles a cpu running at 70-80oC might seem absurb to you based on previous experience and technology, however it is still within a safe distance of the TJMAX and what is has been designed to operate at. I think it speaks volumes that even at higher temperatures the system still maintains stability and operation, having an expectation for better just isn't needed if temperature you're operating within is considered safe and normal. I don't think we've approached the thermal limitation of air cooling its more the heatsink design and material that needs to change.
Originally Posted by 3oh6 Typical Thermalright quality and performance...but the stock i7 965 cooler running the system at 3.9GHz still blew me away, albeit at an average temperature of 92C  |
She be burning up the place, aside from the all the noise any sign of instability at the those temperatures?
I don't know if you have any around, but is there any chance you could chuck a couple of NF-P12's on there.
Regards,
EE
