Old January 19, 2009, 06:57 PM
Digikid's Avatar
Default Noctua NH-U12P or TRUE 1366RT?
Which one of these should I get? The Noctua is the better deal and is in stock at NCIX but the TRUE is out of stock for close to two weeks and only has ONE fan included.
Planning to get at MINIMUM 4GHz out of my I7 920.
Old January 19, 2009, 07:03 PM
Andy's Avatar
I can't speak for cooling an i7, but I have the Noctua on my dual core, and it is great. Very high quality piece as well.
SAGER 5165 - Matte Screen (1920x1080) - i7-2630QM - nVidia 555M - 8Gb DDR3 - 120Gb Corsair Force GT SSD - 500Gb Momentus XT - Intel® 6300
Old January 19, 2009, 07:05 PM
I have the Noctua unit and very happy with it. It should be a few dollars less at DirectCanada which is also owned by NCIX. You have the option of two fans - but the second one is an overkill and does not do too much at all. I added the secon fan
and so far has not seen any marked difference.
ASUS Z97-DELUXE; INTEL i7 4790K ; NOCTUA NH-U12P; PNYGeForce GTX 760 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 10 PRO 64-BIT.
Old January 19, 2009, 07:23 PM
Digikid's Avatar
How is it for Noise Malam?
Old January 19, 2009, 07:55 PM
Jake_HT's Avatar
I'll disagree, it seems that the 2nd fan does in fact some work!
Thermalright TRUE Black 120 CPU Cooler Review
http://jakeht.deviantart.com/
Old January 19, 2009, 07:56 PM
Andy's Avatar
I only have a single fan on mine (Noctua), and it is very quiet.
Old January 19, 2009, 11:15 PM
Eagle Eye's Avatar
Noctua makes great fans that are paired with Thermalright heatsinks
+1 For the thermalright, it would be my first choice for cooling any CPU.
EE
Old January 20, 2009, 04:39 PM
Digikid's Avatar
Just a thought....just saw Linus video on something called a Domino A.L.C.
Good price for it over at NCIX......watchca think?
Old January 20, 2009, 04:47 PM
rjbarker's Avatar
I'm waiting for that Thermalright True from NCIX as well.....does that Noctua come with a Bolt Through Kit or just the clamps?
Firestrike Extreme: 21.452
MARK 11: 32.530
Old January 20, 2009, 05:16 PM
Digikid's Avatar
Not too sure.....I think that for 1366 it uses a backplane like the Tuniq Tower sort of deal.
Question about Noctua NH U12P SE 1366 (Nickel plate, installing both fans issue) appplejack Air Cooling 5 January 13, 2009 01:44 PM
Just got Noctua NH U12P 1366 appplejack Air Cooling 16 December 26, 2008 04:52 PM
Noctua NH-U12P CPU Cooler Review comment thread AkG Air Cooling 8 May 27, 2008 04:34 PM
Noctua NH-U12P Heatpipe CPU Cooler Hardware Canucks Air Cooling 0 May 5, 2008 12:32 PM
