Old January 20, 2009, 06:07 PM
bojangles's Avatar
My Noctua came with a bolt-thru kit if I'm thinking what you're thinking. You have to screw it on to the motherboard, not push-pin like. Really great heatsink. Should dissipate alot of the heat from the i7.
Old January 28, 2009, 08:45 PM
Digikid's Avatar
Okay . They are now BOTH is stock and I have a 100CDN bill in my bank that wants to go somewhere.
I need either one of these units and some MX-2.
Need more suggestions guys.
Old January 28, 2009, 08:52 PM
Jake_HT's Avatar
I'm going to vote for TRUE with 2 fans on it.. Seems like the better cooler (which is why I bought one).
http://jakeht.deviantart.com/
Old January 28, 2009, 09:22 PM
lowfat's Avatar
I'm using a TRUE on my i7 and it does a rather good job keeping it cool with 2 Nexus DS12L-12's on it.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old January 29, 2009, 05:06 AM
Digikid's Avatar
I just thuoght of something....will the MOSFET cooler get in the way if I get the Noctua?
Old January 29, 2009, 05:10 AM
Eagle Eye's Avatar
Hey Digikid what board do you have?
Old January 29, 2009, 06:32 AM
3.0charlie's Avatar
TRUE with dual Scythe Fs did the job at 4.1GHz, until it went under water.
Hydro-Quebec is salivating...
Old January 29, 2009, 06:41 PM
Retro's Avatar
I have been very pleased with my Noctua NH-U12P, I currently have one Noctua NF-P12 fan on it due to clearance issues with a second fan and my TR HR-09 Mosfet sink. No other clearance issues with the heatsink though. MX-2 works well with it. The Noctua fans are very quiet while still putting out decent airflow. The mounting system is what sold me on the Noctua as I had a TRUE previously, it is much more solid and easier to remove and re-install. The temps. were "damn good" with the TRUE however, but only by about 2-3 degrees at load compared to the Noctua for me.
Latest build:
i5 750@3800MHz 20x190@1.38125v
Noctua NH-U12P/NF-P12
4G GSkill DDR3 2000 Ripjaws
Asus P7P55D-Pro
2x EVGA GTX275 in SLI
PC P&C 750 Silencer
Cuda 500
Antec 902
W7 64 RTM
  #19 (permalink)
Old January 29, 2009, 09:24 PM
Silvgearx's Avatar
i got a stupid OT question
Can i use my current TRUE 120 with a 1366 back plate for I7 cpu?
Or would i have to order another TRUE 120?
  #20 (permalink)
Old January 30, 2009, 05:11 AM
Jake_HT's Avatar
You can use your TRUE now no problem:
NCIX.com - Buy Thermalright LGA1366 BOLT-THRU Kit for All Ultra Series HR01 Plus HR01 4U HR01 3U Ultima 90 - BTK-LGA1366R In Canada.
Question about Noctua NH U12P SE 1366 (Nickel plate, installing both fans issue) appplejack Air Cooling 5 January 13, 2009 01:44 PM
Just got Noctua NH U12P 1366 appplejack Air Cooling 16 December 26, 2008 04:52 PM
Noctua NH-U12P CPU Cooler Review comment thread AkG Air Cooling 8 May 27, 2008 04:34 PM
Noctua NH-U12P Heatpipe CPU Cooler Hardware Canucks Air Cooling 0 May 5, 2008 12:32 PM
