  #21 (permalink)
Old January 19, 2009, 05:58 PM
Too far for the cold "water" to go..it would vaporize before hitting the base? You want the fin end hotter than the base end, IMHO...and heatpipes don't really work this way. They circumvent the natural function of teh heatpipe to make it more efficient.
Of course, I really know no more than you do. I just seems to make so much sense to me...as soon as I saw it...
  #22 (permalink)
Old January 20, 2009, 02:21 AM
Eagle Eye's Avatar
Well this is what Thermalright had to say, albiet vague maybe I could squeeze a little more and get some exact figure huh.
Dear Adam:
Many thanks for your mail and support,
Our coolers have been done tested through out
many runs of weight test, and all our coolers have been designed,
to give our users best performances and without the worries
of things such as breakage of the motherboard,
as we have never encountered such complains.
EE
  #23 (permalink)
Old January 20, 2009, 11:02 PM
Eagle Eye's Avatar
Nothing more to add really, a shame I didn't an approximate weight.
Dear Adam:
We have done many tests,
and with the cooler itself installed on motherboard,
even with our TRUE copper it still hardly breaks,
motherboard only breaks if done in freefall testing,
that is have our cooler installed onto the motherboard,
and then throw them down from 5 floor just for example,
then definitely it will break, in other words, today's motherboard is much
stronger than before, and is hardly to break it unless under enormous,
pressure or impact.
EE
  #24 (permalink)
Old January 20, 2009, 11:28 PM
Jake_HT's Avatar
I installed my TRUE tonight, and although it is not as big and heavy as the V10, it's still a big heatsink... and I felt no worries and no flex in my motherboard, it seems the backplate really puts a lot of support on there. But yeah, if you're throwing your PC from 5 floors up, it's GOING to snap!!!!!!
http://jakeht.deviantart.com/
WTB: OCZ XTC Cooler mattlef Buy/Sell & Trade 10 August 16, 2008 04:52 PM
Cooler Master Hydra 8800 GPU cooler (water block?) discussion thread Misoprostol Water Cooling 9 December 8, 2007 12:27 AM
Another peculiar GPU cooler from Cooler Master: CoolViva Pro Review by X-Bit Babrbarossa Reviews & Articles from the Web 7 March 19, 2007 04:19 AM
