Old January 15, 2009, 06:47 PM
Jake_HT's Avatar
Default Core i7 heatsink
Hey guys..
I don't know much about the latest heatsinks so I need some help here.
I'm buying some new things, including the i7 920 CPU, which will be used with an Asus P6T deluxe motherboard, and from what I'm reading my current heatsink won't be enough to handle it for overclocking..
I have a Zalman 9500 right now using it in a Antec 1200 case, and the case provides fantastic ventilation.
I really like the design of the 9500 with the blue LED, and was wondering if the Zalman 9700 cooler would be enough to cool the i7 enough for a decent overclock?
How does the 9700 compare to other air heatsinks? Is the difference huge?
I know that I will have to buy an adapter to fit it, I have that part figured out already, I just need to know if this heatsink will be able to cool it fine.
I will also be getting Arctic silver 5 thermal compound to help as much as possible with the cooling.
Thanks guys.
Old January 15, 2009, 06:55 PM
Only heatsink right now that will work properly and good for the i7 is the True 1366 edition.
Old January 15, 2009, 08:14 PM
I have the Noctua NH-U12P SE1366 in my core i7 965. It works good.
Old January 15, 2009, 08:50 PM
Jake_HT's Avatar
Yeah that looks like a decent option.... comes ready for LGA 1366.
Those fans are hideous though.... I'd probably swap those out
Old January 15, 2009, 09:01 PM
lowfat's Avatar
not true if you can find a place to buy this ::: Zalman, leading the world of Quiet Computing Solutions :::
in Canada.
Old January 15, 2009, 09:08 PM
Jake_HT's Avatar
in Canada.
Yeah that's the clip I'd need for the 9700, called around town and nobody can get a hold of it. It's on newegg.com, but that's american! It's not on any of the cdn sites..
I even emailed newegg.ca and they pretty much said tough luck
If anyone thinks the 9700 will suffice, I'd get it in a heartbeat. Love my 9500.
I will be buying the new stuff on Saturday.
Old January 15, 2009, 10:10 PM
Jake_HT's Avatar
From what I'm reading in the newegg clip reviews... it seems to be keeping the i7 cool with overclocks of 3.5 ghz and higher.... sounds like it's going to work? With the help of the antec 1200's 8 fans.... it should do relatively well.
EDIT: I'm looking into that TRUE... and looks great... 6 heatpipes, good reviews... Only problem is from NCIX it's not available in 1366 yet (1-2 weeks)... and it is at directcanada, but it doesn't specify if it's 1366 version...
I will be buying this stuff on sat... I guess I can use stock cooling until the TRUE becomes available.
Old January 16, 2009, 07:17 AM
Soultribunal's Avatar
I was looking around, however I guess its not available yet to us.
Zalman has the CNPS9900 (which I believe is LGA1366). It got pretty good reviews in its first Run.
Might be worth the wait?
Zalman CNPS9900 LED CPU Cooler - Page 1 of 7 - Big Bruin
Best of luck,
ST
Old January 16, 2009, 07:42 AM
Jake_HT's Avatar
Yeah I was reading about that also, said 5-10 degrees better than zalmans current offerings, however I find that hard to believe considering it's essentially the same design. I couldn't find any solid info on a release date though. How much do you really think I want to wait to overclock my new i7? :)
Old January 16, 2009, 09:04 AM
Don't Mistake it looking the same (Rounded shape) with being the same.
The fan could have higher static Pressure, Higher CFM, the offset of the fins is different. There are a lot of subtle changes that can make each cooler act differently.
Of course, until two can get benched Side by side, it is all subjective.
And no, I wouldn't expect you to have to wait to OC lol.
Best Regards,
ST
Does Core i7 Series have pre-applied thermal paste on the heatsink? appplejack CPU's and Motherboards 7 December 4, 2008 11:49 PM
WTB/WTT: LGA775 Quad Core/Dual Core Chilly Buy/Sell & Trade 7 November 10, 2008 11:46 PM
new cpu heatsink Evylldemon Air Cooling 6 November 10, 2008 03:03 PM
New Heatsink miggs78 Air Cooling 13 June 10, 2008 07:32 PM
FS - Intel Core 2 Duo E6600 Dual Core Processor LGA775 Conroe 2.40GHZ 1066FSB 4MB L2 pat767 Buy/Sell & Trade 0 January 22, 2008 09:00 AM
