Old January 16, 2009, 12:45 PM
I bought Noctua NH U12P 1366.
I use Antec 182 and this case doesn't let out the heat well.
I like the fans included in the kit but I would go for Thermalright 1366 heatsink.
Old January 16, 2009, 03:37 PM
Jake_HT's Avatar
Yeah that TRUE is looking like my best option for sure. I could also put 2 fans on it instead of 1, so should cool very well paired with my wind tunnel case!
I can also put my beloved LED fans on that sucker... I am a big fan of LED's (pun intended!)
Now... just have to wait for it to become available I'll probably still OC with the stock weakness heatsink... think I can get to 3.0 ghz safely? LOL
Old January 16, 2009, 03:46 PM
lowfat's Avatar
you could do 3GHz on stock cooling.
Mael
Big Lian Li
Forever Alone
Old January 17, 2009, 08:01 AM
Jake_HT's Avatar
Ended up getting the TRUE on directcanada and separate adapter! I didn't want to wait Air shipping promo they have is sweet, 10 bucks or air shipping, should be here first.
Old February 1, 2009, 03:20 PM
Bubbzilla's Avatar
Smile What is the best for the money?
I am planning on buying a new computer soon with the i7 920 and Gigabyte GA-EX58-UD5 MOBO with HAF 932 case and i have been looking everywhere for a descently priced cooling fan. I am buying my computer from 2 places (tigerdirect and memoryexpress) and i get the stock intel fan free with the i7. my first question is, is the intel fan any good? My second question is, if not which is the best buy?
Tigerdirect and memoryexpress only have 4 different fans for the i7, none of which are under 70$. My choices and between:
Noctua NH-U12P SE1366 $105
Zalman CNPS9900 (9800/9500 reguire adapter)$100
Thermalright Ultra-120 eXtreme w/mount $85
Thermaltake V1 AX $72
Also, what kind of overclocking could i expect from the best of these, and are these worth the high prices?
Old February 1, 2009, 03:55 PM
lowfat's Avatar
Why not buy from NCIX? You can price match everything from Tiger Direct or other sites.
You can get an Xigmatek HDT-S1283 & Adapter for $55
NCIX.com - Buy Xigmatek HDT-S1283 Direct Touch 3 Heatpipe Heatsink AM2 LGA775 S754 S939 S940 W 120MM PWM Fan - HDT-S1283 In Canada.
NCIX.com - Buy Xigmatek ACK-I7361 Crossbow Mounting Kit LGA1336 775 for HDT-S963 HDT-S1283 RS-S1283 - ACK-I7361 In Canada.
Will perform pretty on par with the TRUE, slighly worse but not very significant.
Mael
Big Lian Li
Forever Alone
Old February 1, 2009, 04:06 PM
Bubbzilla's Avatar
Smile what is the shipping cost?
tiger direct has a 5$ shipping cost for Noctua NH-U12P SE1366 and Thermaltake V1 AX and memory express is free. What is the shipping cost for this site? I am trying to save every penny i can on this so even if i save 5$ and get it from somwhere else it's worth it, even if i have to wait.
also is the Thermalright IFX-14 any good at $80 plus an adapter
Old February 1, 2009, 05:20 PM
lowfat's Avatar
Shipping is like $7.98 to where I live. That still is cheaper than every heatsink you listed. I can almost guarantee you that buying your whole order @ NCIX and price matching will be cheaper than Tiger Direct and Mem Ex.
Mael
Big Lian Li
Forever Alone
  #19 (permalink)
Bubbzilla's Avatar
Smile
thanks
off topic>>>why is i7 920 so much cheaper from tigerdirect then anywhere else? it is only $350 where memxpr in $400 and NCIX is $430. Makes it seem like theres some sort of catch.
  #20 (permalink)
Old February 1, 2009, 06:47 PM
Jake_HT's Avatar
Originally Posted by Bubbzilla View Post
thanks
Newegg.ca has it for $350 also... Not sure why it's so much lower, competing maybe?
I went with the TRUE for my i7 build, temps are fine, but still waiting on my RAM before I OC it..
http://jakeht.deviantart.com/
Does Core i7 Series have pre-applied thermal paste on the heatsink? appplejack CPU's and Motherboards 7 December 5, 2008 12:49 AM
WTB/WTT: LGA775 Quad Core/Dual Core Chilly Buy/Sell & Trade 7 November 11, 2008 12:46 AM
new cpu heatsink Evylldemon Air Cooling 6 November 10, 2008 04:03 PM
New Heatsink miggs78 Air Cooling 13 June 10, 2008 07:32 PM
FS - Intel Core 2 Duo E6600 Dual Core Processor LGA775 Conroe 2.40GHZ 1066FSB 4MB L2 pat767 Buy/Sell & Trade 0 January 22, 2008 10:00 AM
