Old January 14, 2009, 03:13 AM
Default What's the best performance & low noise 120mm fan?
What do you think?
I'm using Noctua NF P12 and think it's pretty good.
Old January 14, 2009, 05:31 AM
Eagle Eye's Avatar
I have 6 of them so I'd say they're pretty good.
Old January 14, 2009, 02:06 PM
CTA's Avatar
CTA CTA is offline
no zm-f3 or yate loon...
For those who think Noctua's are worth $20...
please explain about this reviews
Old January 14, 2009, 02:07 PM
Originally Posted by CTA View Post
x2
Noctua's are overpriced.
Zalman or Yates ftw.
Old January 14, 2009, 02:27 PM
Eagle Eye's Avatar
Intially they are expensive but they have a 6 year warranty to decide that and if they perform they're just cheaper or if they fail I'll just rma it.
Noctua's = Long term Value and reliability
I think the important thing here is the application, assessing your needs and budget when deciding on a fan. Noctua's are considered a premium brand and you pay a premium price.
A more intellectual and less antagonistic view and something I completely agree with.
Originally Posted by Dizz View Post
Hi Bojamijams, I have to say that I completely disagree with your assessment of the Noctua NF-P12s. I have no doubt that you consider them to be poor value & indeed in your case & with your intended usage they may in fact be quite unsuitable.
However, there are situations such as mine where they are unsurpassed & provide the required cooling in absolute silence.
My Workstations have at considerable expense been refitted with Noctua NF-P12s. On average each station has between 8 to 13 Noctua NF-P12s per enclosure; the stations operate 24/7 @ full load & are now also completely silent.
The sheer volume of fans alone has always guaranteed satisfactory cooling but the real issue has always been that over time; “lesser fans” in such volumes, eventually become noisy & collectively very, very noisy. Therefore, to maintain a quite working environment with such a large number of fans per case; my experience to date has been that most fans need replacement within 12 months.
Now if we revisit the concept of value you can see that the Noctua NF-P12s are virtually priceless to me. They are silent now & should remain so over time & should they become noise, at any time in the next 6 years I will return them under warranty, as faulty.
To conclude, if the Noctua NF-P12s are able to perform for the next 6 years in silence then they will be the cheapest fans I have ever purchased! As you can see its horses for courses, I have no doubt that there are enclosures & OC expectations that would be unsuitable for a Noctua NF-P12 but that doesn’t automatically mean that it’s an inferior or over-priced product. Thankfully there are other products from other venders that can fill the many requirements that exist.
Regards, Dizz
EE
Old January 14, 2009, 02:38 PM
MpG's Avatar
MpG MpG is offline
If you're interested in longevity, get some Scythe S-Flex's. A little less of a premium, and they also have FDB bearings, which tend to last a lot longer than sleeve and ball bearings.
Old January 15, 2009, 09:28 PM
Noctua NF-P12 all the way - I have 5 of them! You can get them for $18. at DirectCanada store or wait for a sale on NCIX.
ASUS Z97-DELUXE; INTEL i7 4790K ; NOCTUA NH-U12P; PNYGeForce GTX 760 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 10 PRO 64-BIT.
Old January 15, 2009, 09:46 PM
JD JD is offline
Yeah plus they come in various speeds to tend to all your needs (quiet or more airflow).
Those GELID fans look pretty decent too and go for like $5 on Direct Canada. Not sure how they perform though.
Old January 15, 2009, 10:21 PM
I've had 3 out of 7 yates fail on me since October. All Noctua fans (15+) I have in installed in different systems are still going strong. (And silent too !!!)
If you have to buy a fan or two get Noctua. If you need 3 or more try Scythe S-FLEX.
Electrical Buzzing Noise From PSU Johnnyl168 Troubleshooting 10 December 13, 2008 09:21 PM
When Noise Doesn't Matter Soultribunal Air Cooling 0 December 8, 2008 08:40 AM
Noctua NH-U9B Low Noise Heatsink Review Hardware Canucks Air Cooling 0 April 30, 2008 09:24 AM
8800GT - Strange Noise Voodoo Troubleshooting 34 January 21, 2008 06:45 PM
ultra high frequency noise? magictorch Troubleshooting 14 November 29, 2007 06:27 PM
