Yeah corny title I know,
Tonight I retired the Sunbeam Core Contact in place of a ThermalRight Ultra 120 eXtreme push/pull config with 2 x Noctua NF-P12. Temps are way down about 8-10 degrees across all cores running the same test in the picture. The added fan and likely overall better cooler is a direct results of this, while the Sunbeam is an excellent cooler I think my setup, a poorly ventilated Antec P182 and the lack of additional airflow makes it an unsuitable heatsink for my system. Open cases results are even better temps drop even more about 5-7oC across all cores and idle temps while downclocked to 2.7GHz run near ambient at 23oC not too shabby, although it has been a little chilly here in Toronto.
So anyone out there looking for the ultimate in cpu cooling albeit the most expensive as it goes the ThermalRight Ultra120 eXtreme coupled with 2 x Noctua NF-P12's is where its at.
