Originally Posted by element291 Thanks for the help so far guys!
I have a few more questions.
Is there any of the isopropyl alcohol in small amounts for sale on sites like ncix or tigerdirect? |
Go to your corner drug store, or a Shoppers. Both should have it, depending on the area your in it may be on the counter, or behind it. I've never had to ask for it, as I've always seen it just siting out, but apparently in areas with high drug issues it can be hard to get the stuff, even when you ask for it.
If its behind the counter, and they ask why you need it, tell them the truth! Just explain that it makes for a great electronics cleaner, and you need some as your reseating a processor. It will just sound like jargon to them, but hopefully they understand your not going to be using it to make drugs.
