Bad Resonance insulation I would guess. *the fan's bearing style could possibly be sending the vibrations in a directional way, but I'm no Wave Theory Engineer*
I still stand by my theory of using Dampening Material to solve this. If you create a cushion for the vibrations to go into, you will most likely solve the issue.
I believe you when you say its the side of the physical case.
I was merely going over everything in my head really.
I always believe *much like when I work on cars* fix with the cheapest solution first, before changing the big stuff.
Good Luck man,
ST
__________________ "We know not why he calls for us, only that when he does we must answer" - DMP 2009 "Dear Iceberg, I am sorry to hear about global warming. Karma is a bitch. Signed - Titanic" I would rather believe and find god doesn't exist than to not believe and find that he does. |
