Old December 29, 2008, 08:03 PM
Dar_ell's Avatar
Default Temperature problems =/
Hey guys I'm having a problem with system temperatures. When i open CPUID hardware moniter i always see my system temps really high, higher then my cpu temperatures =/. This one time playing a normal game i got it to 80C!!! any clues?
"My brother is dead. He's not here Anymore. But on my back, and in my heart...He lives on in me. I will make a hole through heaven itself, even if that hole becomes my grave. As long as I break through, I will be victorious.Who the **** do you think I am?"
Old December 29, 2008, 08:06 PM
3.0charlie's Avatar
The DS3L runs hot stock, but not that high. I don't know the HAF (never used it), but make sure you have proper airflow. You can always try to use your computer with the side panel removed and check your temps. If lower, you have an airflow issue.
Hydro-Quebec is salivating...
Old December 29, 2008, 08:07 PM
sswilson's Avatar
You can try redoing the thermal compound on the NB cooler (I do it just on spec now whenever I get a new board), or if you want to track it down you can leave the side off and hold a 120mm fan in your hands to direct it at different areas of the board to see if any particular spot will bring the temps down.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old December 29, 2008, 08:32 PM
Dar_ell's Avatar
well right now im only going to redo the thermal compound once my bolt thru kit comes in the mail. I HATE PUSHPINS ARRHGHHHGH.. ok calm down... whew. anyways i can feel tons of hot air from my GPU, the airflow is nice. the temperatures feel like 25-30C.
Ok something odd just happened.... I put my e8400 from 3.6ghz to 3.2ghz and the system temps drop to 30C. Could it be that my CPU is creating so much heat? If anyone got some options to replace those big 230mm fans please share.
Max temperature Vinnie Overclocking, Tweaking and Benchmarking 4 November 28, 2007 09:08 PM
Way too many temperature readings! Mibs Water Cooling 2 August 4, 2007 12:00 PM
Fan speeds, temperature... omgwtf CPU's and Motherboards 21 May 25, 2007 04:58 PM
Temperature Thresholds??? mattydies Overclocking, Tweaking and Benchmarking 5 April 19, 2007 01:08 AM
C2D temperature woes Babrbarossa CPU's and Motherboards 35 April 1, 2007 12:39 PM
