Old December 28, 2008, 01:01 PM
Shadowmeph's Avatar
Default what is normal idle temp for e8400
I put my pc together almost a year ago and am wondering what the normal average temperature for my duo core e8400 cpu on a Gigabyte p35 MB using a ThermalRight Ultra 120 Cooler with single 120mm Yate loon
Old December 28, 2008, 01:18 PM
There is no "normal" temp.
Ambient temps play a major role.
But if I was to say taking ambient in .. 35-40
Old December 28, 2008, 01:36 PM
Shadowmeph's Avatar
hmm ok so how do I find my ambient temp?
Old December 28, 2008, 01:37 PM
get a thermometer for your room?
Old December 28, 2008, 06:03 PM
I use my motherboard temp as a guide for the ambient - its about 2 - 3 degrees higher than the room temperature. Also your CPU temperature will be a function of how good your computer case and the CPU Cooler gets rid of hot air. I have an Antec p180 with a case fan at the front, one at the rear and a third at the top of the case. With this arrangement, my motherboard is 23C and CPU at 26C at idle ( just normal use - as I am typing this message). I have the CPU running at 3.2G also, but it stays at 2.2G during idle unless there is a load. Under a stress test (Everest Stability Test) the max I get is 41C.
ASUS Z97-DELUXE; INTEL i7 4790K ; NOCTUA NH-U12P; PNYGeForce GTX 760 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 10 PRO 64-BIT.
Old December 28, 2008, 09:26 PM
Motherboard temp and ambient temp will never be close due to many variables like case heat dumped from a video card, heatsinks or even the chipset.
Most accurate way is simply as stated get a thermometer.
Old December 28, 2008, 11:43 PM
1Tanker's Avatar
My system:
-8400@3.6(400x9-1.264v/CPU-Z right now) TRUE/MX-2/120x25..95cfm
-GA P35-DS3L
-HIS HD4850/stock(+Stock cooler)
-CM690/6-7 120mm
-2x1GB Ballistix PC2 8500 (400@4-4-4-10)
-2xWD640(non-RAID),1xWD500,1xSeagate 320GB(OS)
-Samsung 18x DVD Burner
-52-in-1 card-reader
-VX550 drawing from bottom, then out back(no help cooling case)
-XP-Pro SP2
Idling @ desktop/surfing, Core 0=44C, Core 1=39C..with room temp of 26.5C(quite warm).
Edit: all C1E, EIST off
Old December 29, 2008, 09:13 AM
I agree, but in my case I have Thermometer sitting on my computer desk and have found that its 3 deg lower than the motherboard. I am not sure though, if this relationship will hold if the temperature in the room goes up.
Old December 29, 2008, 11:00 AM
Shadowmeph's Avatar
hmm ok so I am off to the Dollar store to pick up a thermometer . I have the program coretemp running and it says that (right now just on the net typing this) core#0=38-39 and core#1=39-40. I just needed to know because I will be attempting my first Overclock ever so I needed a base line. which programs are goo to use for this sort of thing?
Old December 29, 2008, 12:03 PM
burebista's Avatar
E8400, Ninja + Bolt-Thru (fanless) now at 22C room temperature in idle.
and after a couple of minutes of Orthos
E8400 very high temp on P5Q PRO Friends123 CPU's and Motherboards 21 December 23, 2008 08:24 PM
just dropped my idle temp by... rob123 Video Cards 11 July 23, 2008 09:03 PM
E8400 Idle Temps... rjbarker Overclocking, Tweaking and Benchmarking 13 April 14, 2008 02:36 PM
CS:S ti normal program Long John Silver Gaming 5 June 21, 2007 07:32 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
