Old December 27, 2008, 08:02 PM
Lima's Avatar
Default Help for making custom back plates.
Hi peeps,
I am gonna be installing my new CPU heat sink and new MOSFET heat sink.
I have a back plate for the CPU heat sink but, my MOSFET heat sink uses push pins and I want to make a back plate for it.
If you guys got any suggestions, advice, guides/instructions or recommended places for materials... post away, I am all ears.
Old December 27, 2008, 08:43 PM
JD JD is offline
Just make something like this:
EKWaterBlocks.com SHOP
Piece of foam + metal plate then the according nuts and bolts.
Old December 28, 2008, 06:28 PM
Lima's Avatar
I got the plate made today and got a bicycle tire tube that I will cut up to use as a cushion between the plate and board. I got the right screws but I am gonna return them as I found the perfect ones that will suit my needs even better.
I' m just gonna have to be patient as my work leaves me little time for this stuff during the week.
Thanks jdrom17.
HOW TO: Making a USB Thumbdrive Bootable Supergrover Guides & How-to's 43 January 29, 2012 12:55 AM
Making icons in ubuntu biff O/S's, Drivers & General Software 10 January 8, 2009 06:09 PM
Swiftech mcw60 260/280 Hold-down plates released! ragenrok Water Cooling 0 September 17, 2008 10:13 AM
Cod4 Map Making cmac79 Gaming 0 May 12, 2008 04:41 PM
My new OC rig (it's in the making) Dus CPU's and Motherboards 3 August 10, 2007 12:33 PM
