Old December 25, 2008, 08:27 AM
CORE's Avatar
Default Hello Again Re: OCZ VENDETTA 2
Hi again guys.
Uhh i bought the OCZ Vendetta 2 HSF but i hate the pushpins is there any other methods?
Is the retention bracket of TRUE compatible w/ OCZ VENDETTA 2?
Thanks
Old December 25, 2008, 08:43 AM
Dar_ell's Avatar
I heard this one works with the OCZ vendetta 2 NCIX.com - Buy Thermalright LGA775 BOLT-THRU Kit for Ultra 90/120 & HR-01 Retail Box - BTK-LGA775R In Canada.. If I'm wrong someone enlighten me.
"My brother is dead. He's not here Anymore. But on my back, and in my heart...He lives on in me. I will make a hole through heaven itself, even if that hole becomes my grave. As long as I break through, I will be victorious.Who the **** do you think I am?"
Old December 25, 2008, 08:45 AM
paphman910's Avatar
Yes there is!
socket 775:
Paphman910:
(PC Power & Cooling Silencer 610) (Asus P5K-E/WiFi-AP) (Xeon E3110) (G.Skill 4GB DDR2-6400 800) (8800GTS 512 MB) (Seagate 500GB) (Pioneer 212D DVD Burner).
Old December 25, 2008, 09:46 AM
I believe the Zigmatek unit is more of a perfect fit. Its made for the Xigmatek version of the Vendetta.
NCIX.com - Buy Xigmatek ACK-I7751 Crossbow Mounting Kit for 3 Piece Heat Pipe for HDT-S963 HDT-S1283 RS-S1283 - ACXTACK-I7751 In Canada.
ASUS Z97-DELUXE; INTEL i7 4790K ; NOCTUA NH-U12P; PNYGeForce GTX 760 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 10 PRO 64-BIT.
Old December 25, 2008, 09:48 AM
Incorrect.
Purchasing the Thermalright one is the best.
You remove the stock pins off the Vendetta then use the screws and backplate with the stock V2 bracket.
Old December 25, 2008, 10:08 AM
Dar_ell's Avatar
Originally Posted by enaberif View Post
Incorrect.
Hey enaberif im guessing you have experience installing it, a few questions. Is it hard to screw it in because of the size of the heat sink? Also would i see any difference if i used that instead of the pushpins (one of my pushpins are broken because i kind of pushed it too hard, those things are fustrating..)
Old December 25, 2008, 10:27 AM
The screws can be a bit difficult to screw in but it is manageable.
And if your pushpins are broken then don't use it at all.
Old December 25, 2008, 11:01 AM
Dar_ell's Avatar
Yea i would replace it if i could get my hands on the bolt thru kit. (personal difficulties)
Old December 25, 2008, 11:41 AM
DRYJESUS's Avatar
Restricted Poster
Sorry, still using stock cooling, but what's wrong with the push pins?
Old December 25, 2008, 11:44 AM
Doesn't provide a very good secure and good contact between cpu and heatsink.
[WTB] Vendetta 2 Infiniti Buy/Sell & Trade 4 November 27, 2008 09:06 AM
OCZ Vendetta II Mr. Gruntsworthy Air Cooling 16 September 30, 2008 05:20 AM
FS: True 120 / Vendetta 2 enaberif Buy/Sell & Trade 9 September 21, 2008 09:43 AM
OCZ Vendetta 2 is badass! ricknash61 Overclocking, Tweaking and Benchmarking 4 September 7, 2008 04:43 PM
