Old December 24, 2008, 09:15 PM
lowfat's Avatar
Default help me solve my videocard cooling issues. *PIC*
As you can see, I have a problem.
I am more worried about the Sapphire 4870 (red one) as it really has no where to pull air from. The Palit 4870's (black one obviously ) fans aren't completely covered so I think it may be better off. Is there any low-profile heatsink out there that can handle a 4870 and half room to breathe, or an I pretty much effed?
Old December 24, 2008, 09:28 PM
CMetaphor's Avatar
Quadfather
Thermalright HR-03 GT? Fits a 4870 and you can flip it over to the high side of the card for more room. If that doesnt work, you cant also try the tRad from them as well.
Old December 24, 2008, 09:32 PM
lowfat's Avatar
I have a card directly below the 4870 as well though. So I don't think the HR-03 GT will fit. And the TRad2 is a double slot cooler, unless passive. And I don't think it will cool a 4870 without a fan.
Old December 24, 2008, 09:33 PM
Chilly's Avatar
Watercool it all!
Old December 24, 2008, 09:37 PM
CMetaphor's Avatar
Quadfather
What card is above it? I have a HR-03 GT on my 3850, and it wraps around my TV tuner card in my HTPC And runs passive... Still no other way?
Old December 24, 2008, 09:44 PM
MpG's Avatar
MpG MpG is offline
The cards are both 4870's, right? What about switching them? It wouldn't solve the problem, but the Palit might do better than the Sapphire in those circumstances.
How about this cooler? Depending on your case's airflow, you might still come out ahead, even without actually attaching a fan to it.
Old December 24, 2008, 10:04 PM
lowfat's Avatar
Originally Posted by Chilly View Post
Watercool it all!
definitely not. I am done with water for good.
There is/will be a RAID card and sound card above it.
Actually if i swap them, the Palit would die a horrible death. It is 3-4mm higher it is nearly touching the card above it.
I actually had a TRad2 ordered today, but removed it because I didn't think it would work passively. Maybe I'll order it and see if it is possible. Although I have my doubts if it be able to handle it.
I could also put the one videocard in the very last PCIe 16x slot however I haven't found a longer crossfire cable for sale anywhere.
Old December 24, 2008, 10:20 PM
MpG's Avatar
MpG MpG is offline
It's surprising what those aftermarket coolers can do passively. You may not brag about the temps, but the card will be more than happy. I ran my 8800 GTS 640 on air for a while, using an HR-03 cooler "passively". The intake fan on the Sonata III case basically blew at the card/cooler, and kept temperature more than acceptable. Just a thought.
Old December 24, 2008, 11:34 PM
I'm not sure what case you're using..so I don't know how much space is between the end of the card and the case. I read a review of the Scythe Musashi Cooler on HardwareLogic and it seems pretty good.
Here's a link: http://www.hardwarelogic.com/news/13...008-12-22.html
Old December 25, 2008, 12:36 AM
lowfat's Avatar
Looks to be slightly wider than that stock heatsink, so that would be a no go.
What do you all use to stress test your Videocard? Gameplaywarrior Overclocking, Tweaking and Benchmarking 5 October 11, 2008 02:12 PM
How to play HD content directly from Videocard Dashock Troubleshooting 9 June 12, 2008 03:47 PM
LF: PSU, Good Videocard, AM2 Heatsink, 2gb/4gb of DDR2 RAM, HDD thatguy Buy/Sell & Trade 6 May 19, 2008 04:35 PM
LF: Mid-Ranged Videocard around $100 thatguy Buy/Sell & Trade 17 May 19, 2008 04:33 PM
WTB Videocard ATI 3850/3870 or nvida 8800 genx Buy/Sell & Trade 0 January 22, 2008 08:26 AM
