  #21 (permalink)
Old February 3, 2009, 01:24 PM
Can I suggest a 120mm fan blowing at the cards from the "radeon sticker" side, plus one at power-end?
  #22 (permalink)
Old February 3, 2009, 01:52 PM
Cptn Vortex's Avatar
Maybe try the Thermaltake Duorb? It uses 2 x 80mm fans. I used one for a time on an 8800GTX and it was decent, not too sure if the 4870 uses more or less power? i put one on some 3850's of mine and their temps are staying in the low 30's...
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
  #23 (permalink)
Old February 3, 2009, 01:54 PM
lowfat's Avatar
Actually I had DuOrbs on my 8800GTs which had the same problem as the cards were side-by-side. The DuOrbs were even worse. Caused the cards to overheat nearly instantly.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #24 (permalink)
Old February 3, 2009, 02:08 PM
lowfat's Avatar
I just did something similar. Before I had a Lian Li exhaust fan right next to the videocards. Well I moved it to the outside of the case pushing making it an intake fan. Then I put a 70mm fan (all that will fit in the PC-A05 before it hits my hotswap bay). And temps have dropped...well sorta. To 112C .
Queen of Dreams WIP
Big Lian Li
Complete
  #25 (permalink)
Old February 3, 2009, 02:17 PM
Sheesh. But you know part of the problem is the palit card not exhausting out the back...what a poor design for a heatsink!
running 2xreference 4870 I saw 98c loaded, but it didn't artifact or anything, same slot config(BadAxe2). I'm pretty sure 105c is throttle, 120c shutdown.
  #26 (permalink)
Old February 3, 2009, 06:53 PM
lowfat's Avatar
I tried every fan combination I could think of, always ended up with it locking the system up on load. Either I find a longer crossfire bridge cable or I buy the Akasa Vortexx Neo (for like $50US shipped).
Queen of Dreams WIP
Big Lian Li
Complete
  #27 (permalink)
Old February 7, 2009, 12:01 PM
lowfat's Avatar
Well I don't have to worry about it now. Because I sold the Palit 4870 and the Sapphire 4870 dies the next day
Queen of Dreams WIP
Big Lian Li
Complete
  #28 (permalink)
Old February 9, 2009, 05:24 PM
Eagle Eye's Avatar
Ouch, did you just replace it with a 295 instead and forget crossfire all together.
Are you going to even attempt to RMA the sapphire?
EE
  #29 (permalink)
Old February 10, 2009, 06:08 AM
Soultribunal's Avatar
Damn.... Sorry to hear bout your luck there Lowfat...
Hopefully you can get back up and running with a different setup that won't run as hot.
Regards,
ST
www.realhardwarereviews.com
What do you all use to stress test your Videocard? Gameplaywarrior Overclocking, Tweaking and Benchmarking 5 October 11, 2008 02:12 PM
How to play HD content directly from Videocard Dashock Troubleshooting 9 June 12, 2008 03:47 PM
LF: PSU, Good Videocard, AM2 Heatsink, 2gb/4gb of DDR2 RAM, HDD thatguy Buy/Sell & Trade 6 May 19, 2008 04:35 PM
LF: Mid-Ranged Videocard around $100 thatguy Buy/Sell & Trade 17 May 19, 2008 04:33 PM
WTB Videocard ATI 3850/3870 or nvida 8800 genx Buy/Sell & Trade 0 January 22, 2008 08:26 AM
