<~----> Just got Noctua NH U12P 1366 - Page 2 - Hardware Canucks
Old December 23, 2008, 05:39 PM
Supergrover's Avatar
Originally Posted by sswilson View Post
Not always true... I've got some that don't work that way. Apparently there isn't an industry standard.
Yep, go by the airflow indication on the fan body.
I have found the odd fan that doesn't conform to standers but not in awhile they were all 80mm, I just look at the curve of the fin
Old December 23, 2008, 06:42 PM
SugarJ's Avatar
Originally Posted by SugarJ View Post
The side of the fan with the bars goes against the heatsink. That will push air through the HSF.
So, I was right in this case, but I can't always expect to be right. If I had known the noctua's had arrows on them(my answer went up before the photos), I would have just pointed.
Old December 24, 2008, 09:02 AM
I have the same unit, and you've installed it correctly. You should also check to make sure that you increase the speed of any case fan at the back your case to at least the same speed or higher than the Noctua. This will ensure that whatever is coming out of the noctua is exhausted right away.
I ran the Stability test (CPU stress test) of Everest for 12 hours (CPU @3.2G) and the maximum that I got was 41C. As I am typing now, my idle is sitting at 26C with the motheboard at 23C - I have 20C in the room.
ASUS P6X58D-E; INTEL i7 950 ; NOCTUA NH-U12P; PNYGeForce GTX 460 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 8 PRO 64-BIT.
Old December 25, 2008, 08:38 PM
Thanks. How can check the fan speed and change the heat sink fan accordingly?
I got two fans in the case - one on the rear and the other one at the top.
Old December 26, 2008, 09:21 AM
I have the Noctua fan running at the default max (1366 rpm). I have a fan controller on the other fans and can adjust their speed. If you don't have a controller, you should allow the rear and the top fan to just run at their max speed. Usually those fans run at 1200 - 1500 rpm. What type of case do you have?
Old December 26, 2008, 01:21 PM
I got Antec P182. There are fan speed controllers at the back.
I set them at low speed but the temperature of CPU, Vreg, and system seem to be ok.
On full load the CPU almost never goes above 50C.
I overclocked it up to 3.8GHZ
Now that I got a new heat sink, I'm going to sell the stock CPU heat sink.
What might be a good price for this? It's been only 2 weeks since I built my computer.
Thanks for the answer on heat sink.
Old December 26, 2008, 03:52 PM
Thats cool ! I am not sure of how much you can get for a stock heat sink since it alwys comes free with a CPU. Try and see what offers you get.
Buy LGA 775 or go with LGA 1366? HermesĄ˘ New Builds 9 November 28, 2008 08:30 AM
Noctua NH-U12P CPU Cooler Review comment thread AkG Air Cooling 8 May 27, 2008 04:34 PM
Noctua NH-U12P Heatpipe CPU Cooler Hardware Canucks Air Cooling 0 May 5, 2008 12:32 PM
Noctua-News: Noctua introduces NH-U9B CPU cooler Scotch Tape Press Releases & Tech News 1 February 25, 2008 06:33 AM
