Old December 13, 2008, 08:30 PM
Default Best thermal compound?
acrctic silver? mx-2? i heard those are pretty good, i'm using the one zalman packs with there hsf's and i think it's working alright, not failing thats for sure =P
CPU:Intel i5 6600k - Corsair H110
GPU:EVGA GTX980Ti FTW Edition
HDD:250GB Samsung Evo 850 SSD, 3TB WD Black
MOBO:Asus Z-170 Deluxe
RAM:G.Skill Ripjaws V F4 2800mhz 16GB
PSU:Silverstone 950W
CASE:Silvertstone TJ07
Keyboard:Logitech G15 V2
Mouse:Razer DeathAdder
Case Cooling:2x92mm exhaust,2x120mm exhaust, 2x120mm Ultra Kaze(3000RPM)intake.
Running:Win7 64-bit Ultimate
Old December 13, 2008, 09:19 PM
Neolithium_Wpg's Avatar
I have some OCZ Ultra 5+ (It's Rebranded Arctic Silver) right now and it seems to work well, though I'll be trying out the OCZ Freeze stuff on Tuesday-ish and see how that goes.
Dell XPS8700 | Asus x101ch | iPhone 5 (iOS7)
A Veteran, whether Regular Force, Reserve or Retired- is someone who, at one point in their life, wrote a blank cheque made payable to the Dominion of Canada for an amount of "Up to and including my life"
-Author Unknown
Old December 14, 2008, 03:23 PM
MX-2 is supposed to be good, it's also non-conductive so you don't have to worry if you accidentally get some on the motherboard and don't realize it.
Old December 14, 2008, 03:35 PM
ebdoradz's Avatar
mx-2 or ocz freeze
artic silver will dry faster then the 2 others .... for the price MX-2 is the better choice.
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
Old December 14, 2008, 05:21 PM
Soultribunal's Avatar
OCZ Freeze is what I use. No curing time, pretty effective too.
Everyone has there own uses, but any of the highend ones mentioned are very good, within a half degree of each other in reviews.
Regards,
ST
www.realhardwarereviews.com
Old December 14, 2008, 05:53 PM
Why are there questions about thermal compound in the peripherals section? lol
You putting it on your keyboard or mouse?
Old December 14, 2008, 05:58 PM
lol i dont know where else to put it...theres no general cooling section for "cooling accessories" ...only..case..air..and water...and you'd use thermal compound on all those applicaitons....except case
Old December 14, 2008, 05:59 PM
Exactly; you answered my question lol. It belongs in either of the cooling subforums.
Old December 14, 2008, 06:02 PM
but then i wont get to hear from different sides of experience!...especially case coolers lol
Old December 14, 2008, 06:06 PM
Supergrover's Avatar
I used to be a staunch AS5 man but MX-2 is my new fav, no cure time and not conductive.
Thread Moved to Cooling
R.I.P.
Thermal Compound Removal Help no_pulse Guides & How-to's 36 May 7, 2010 10:45 PM
Thermal Compound Review no_pulse CPU's and Motherboards 5 July 23, 2008 01:50 PM
change of thermal compound v0maru CPU's and Motherboards 0 March 18, 2008 08:13 AM
RMA your board...get thermal compound on your cpu socket! Mibs Troubleshooting 8 September 24, 2007 04:58 PM
How to properly apply thermal compound Corpus Masochist CPU's and Motherboards 9 August 11, 2007 08:12 AM
