I installed the Antec one shown, but find that only the "medium" setting is acceptable noise-wise (despite the fact that I have 9x-10x other fans in my case). As for CFM, I'm not exactly certain but I would guestimate it around 40CFM or so. I'll be trying out a Coolermaster 200mm soon that was taken from the CM HAF 932 case (thanks to B1lk1 for that one), I'll let you know how it turns out (if I can find a place to mod it.... i mean mount it).
In regards to the Kaze fans you're looking at, the first link "Quiet fan" version just seems to be an updated page for the other one, as all the specifications for both are Exactly the same (I mean really the same: CFM, rpm, bear-type, size, mtbf, etc).
I'd suggest picking up a few of these if you're looking for more airflow from a bigger fan:
Scythe "KAZE MARU" 140mm Case Fan
I'll be picking up three of these for use with my recently-aqquired IFX-14 (thanks 3.0Charlie) on my upcoming AM3 Deneb build - Stay tuned for that one, I'm looking beyond 4Ghz on air.
Hope all the info helps.
EDIT:
Originally Posted by enaberif Then you had a improper fan or the fact that the grille of the fan was causing turbulence in creating extra noise.
By no means should a 120mm fan be noisy unless its garbage. |
Actually, it was more of an airflow issue. A standard case fan didn't provide enough airflow out of the huge opening (and there are holes all around the 120mm fans spot). So using a higher CFM fan just added noise but not enough airflow. Using the "bigboy" 220mm gave me higher CFM without added noise.
