Old December 12, 2008, 07:05 PM
MpG's Avatar
MpG MpG is offline
It's a gimmick. But that said, I'm actually beginning to suspect that having some airflow across the back of my motherboard MIGHT be worth a degree or two, it a situation where the board is completely saturated with heat. Hard to say for sure, though. Have to try to test that sometime.
Old December 12, 2008, 07:08 PM
CTA's Avatar
CTA CTA is offline
i see...
last question... what about install 80x80x15mm on back of CM690? it would be cheaper than install ifx-10
Old December 12, 2008, 07:16 PM
3.0charlie's Avatar
Originally Posted by CMetaphor View Post
I personally think that the IFX-10 would be better suited in places where extremely small heatsinks are required (like in an HTPC). It should work better since the actualy CPU cooler isn't very efficient so the backside cooler could theoretically help more. My IFX-10 (that I got with IFX-14 from 3.0Charlie, thanks again btw) will probably get used in my HTPC case or another HTPC build with passive cooling. That way, the case's natural airflow will have a chance to hit the IFX-10 and assist in cooling the CPU beyond just the passive cooler. Just my 0.02$.
Agreed, but usually HTPC cases are rather small and fitting an IFX-10 inside would be tricky.
Still like the IFX-14? It was my pleasure!
Hydro-Quebec is salivating...
Old December 12, 2008, 07:23 PM
CMetaphor's Avatar
Quadfather
I'll certainly have fun trying to put it in my HTPC. I already have a CM GeminII inside a Sugo-03, lol. The IFX-14 however, won't have a nice processor to cool for a little while (at least not until some vacation days come around).
