Old December 12, 2008, 09:10 AM
dadzilla's Avatar
Default Vendetta2 - Fan is loud?
So I really like my Vendetta2 in that the cpu is nice and chilled. But the thing sounds like a bloody B52 on takeoff unless I turn it down to about 80 percent. Anybody else having this problem?
I build, I game, I upgrade. I build, I game, I upgrade. I build.....
Old December 12, 2008, 09:14 AM
You need to go into your bios and adjust the fan speeds.
Any decent bios should allow this.
Old December 12, 2008, 09:16 AM
dadzilla's Avatar
Yes - good point and i will be doing that next.
Old December 12, 2008, 11:28 AM
Soultribunal's Avatar
You could always Replace the Fan as well with a Scythe PWM Version. They use better bearings according to a few people that are quieter.
REgards,
ST
www.realhardwarereviews.com
Old December 12, 2008, 12:12 PM
Dashock's Avatar
Dadzilla you could always replace the fan with a Noctua Nf-p12 will keep it silent and cool. My 2 cents.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old December 12, 2008, 09:54 PM
dadzilla's Avatar
So now I will try the Noctua Nf-p12 I think. Does it mount up the same way as the stock fan?
Low (as in not loud) hi pitch noise from SyncMaster™ 2693HM Gameplaywarrior Display Units 6 November 23, 2008 08:23 PM
Vantec Stealth Fans are Really loud? arekieh Air Cooling 4 November 19, 2008 10:53 PM
High powered power supplies with loud fans Misoprostol Power Supplies 8 April 23, 2007 01:34 PM
Having a heck of a time with an Auzentech X-Mystique. Can't get it loud enough? Misoprostol Audio 24 March 29, 2007 10:46 AM
