Old December 11, 2008, 09:17 PM
CTA's Avatar
CTA CTA is offline
Default top 10 cpu cooler
do you agree this article at Top 5 Intel & AMD Heatsinks on Frostytech ?
i am trying to choose something new other than thermalright TRUE black...
ps you will see HWC banner there...
Old December 11, 2008, 09:23 PM
I agree.
The top 2 work just as good as the true and cost less.
Old December 11, 2008, 09:29 PM
CTA's Avatar
CTA CTA is offline
probelm is OCZ vendetta2 is not in top 10... unlike HWC's review..
Old December 11, 2008, 09:31 PM
They all do the same thing.. pretty much same temps.
Old December 11, 2008, 09:35 PM
CTA's Avatar
CTA CTA is offline
well about 3 to 4 degree different...
is it same to your both cpu cooler? (i believe you owned thermalright ultra 120 before)
i still wonder like to know what is minimum and maximum temperature for watercooling...
Old December 11, 2008, 09:37 PM
I saw very little difference between the Vendetta2 and the True.
Old December 11, 2008, 11:50 PM
Wasn't the Vendetta 2 a slight improvement from the Xigmatek S1283, at least I remember seeing few reviews where the vendetta did perform slightly better. If that is true, you question is answered. But as enaberif said pretty much same temps all around, so Xigmatek should be good for you.
Old December 12, 2008, 12:06 AM
Infiniti's Avatar
Yep, the Xigmatek should be fine. I'm using it on my rig right now, and load only reaches 37C max, with folding 24/7. Oh and you might want to know that I'm using the push pins that came with it.
Old December 12, 2008, 12:28 AM
CTA's Avatar
CTA CTA is offline
i see... okay...
and anyone hears of this new product from coolermaster?
V8 - Cooler Master
impressive or not?
btw please anyone can answer my question about watercooling...
Old December 12, 2008, 01:15 AM
I see no question here about water cooling. Too big of a heatsink, the Xigmatek still is probably better for the simple fact that it is direct heatpipe touch rather than a copper base. Get the Xigmatek, Thermalright LGA775 bolt thru kit and a different fan to accompany it, the original isn't bad, but something like a Noctua will make it much worthy.
Which cpu cooler? Scart Air Cooling 10 March 21, 2008 09:37 AM
Cooler Master Hydra 8800 GPU cooler (water block?) discussion thread Misoprostol Water Cooling 9 December 8, 2007 12:27 AM
Another peculiar GPU cooler from Cooler Master: CoolViva Pro Review by X-Bit Babrbarossa Reviews & Articles from the Web 7 March 19, 2007 04:19 AM
