Old December 12, 2008, 01:36 AM
CTA's Avatar
CTA CTA is offline
Originally Posted by CTA View Post
i still wonder like to know what is minimum and maximum temperature for watercooling...
v8 = 74.12 << new price so wait for next month... or sale...
thermalright TRUE black = 73.08 + 10 for each fan... just two fans make a different...
vedentta2 = 30.70 + 7.95 = 38.65 or extra 10 for better fan... i rather to use it than xigmatek...
xigmatek = 36.58 + 7.95 = 41.56
noctua nh-u12p = 77.99
Old December 12, 2008, 01:38 AM
well about 3 to 4 degree different...
is it same to your both cpu cooler? (i believe you owned thermalright ultra 120 before)
My e8600 @ 1.44v running at 4.6ghz is idle around 32-34 degrees and P95 small FFT at 65 degrees.
Old December 12, 2008, 01:43 AM
CTA's Avatar
CTA CTA is offline
and may i please know your current air cooling?
thank you very much...
Old December 12, 2008, 01:44 AM
I don't.
I quit air cooling once I went water.. much quieter and efficient.
But with air I'd see a +/- 10 degree difference on idle.
Old December 12, 2008, 01:49 AM
CTA's Avatar
CTA CTA is offline
i see.. i ask because of your room temperature...
Old December 12, 2008, 01:50 AM
Same room temps.
Water cooling is more efficient and removing excess heat than a air cooler.
Air coolers all have a max TDP where they can no longer properly dissipate heat.
With water cooling it does as well but it more relies on fans and your rad in the system for getting rid of heat.
Old December 12, 2008, 01:56 AM
CTA's Avatar
CTA CTA is offline
watercooling setup is like over 100cdn... not worth of my time... aircooling do fine job anyway...
Old December 12, 2008, 07:45 AM
Soultribunal's Avatar
Personally speaking, I like the ZeroTherm FZ-120 with Push/Pull Setup. It does well to compete with some top end coolers out there. But, sure I know its not the absolute best out there, but it does a really good job at a decent price.
WC setups done right can cost a lot more than $100, but again its application based. If your pushing your system to the edge, WC is better.
My thoughts at least,
But I feel they have that List pretty close to accurate. Every site will have some preferances of their own. Its up to you to decide which one suits both your budget and application.
ST
www.realhardwarereviews.com
  #19 (permalink)
Old December 12, 2008, 04:45 PM
I am begining to think that the performance of any CPU Cooler is dependent on more than the model of the cooler. Other factors like the particular CPU, how the cooler is installed (push pins or direct mount), and in particular, the air flow of the case will determine how efficient the cooler is. I had a Vendetta 2 installed using the push pins for the last two weeks. I tried to look for a direct mount bracket but could not find a suitable one. I never trusted the push pins, so I decided to switch to the Noctua NH-U12P which comes with its own mounting brackets, and of course, one of the best fans around. Here is what I found !
Vendetta 2 installed with pins:
Ambient: 23 Deg C
CPU Temp at Idle ( Internet Surfing only) - 37 Deg C
Everest System Stability (5 minutes, CPU @100%) - 48 Deg C Max.
Noctua NH-U12P - Direct Mount:
Ambient: 23 Deg C
CPU Temp at Idle ( Internet Surfing only) - 34 Deg C
Everest System Stability (5 minutes, CPU @100%) - 38 Deg C Max
With the Noctua Cooler, my overall system is also running quieter. I have the Antec P180 Case with three case fans - one at the front (intake @1100 RPM), the second at the rear (exhaust @1500 RPM and the third at the top (exhaust @500RPM). The Noctua's CPU fan is running at 1330RPM.
ASUS Z97-DELUXE; INTEL i7 4790K ; NOCTUA NH-U12P; PNYGeForce GTX 760 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 10 PRO 64-BIT.
  #20 (permalink)
Old December 12, 2008, 05:00 PM
Chilly's Avatar
Air cooling? Whats air?
Watercooling IMO > ALL Aircooling.
That being said, if you don't have the dough to go under water, than coolers such as the TRUE and Xiga are pretty good. Theres only so far you can go with air thou...
Which cpu cooler? Scart Air Cooling 10 March 21, 2008 09:37 AM
Cooler Master Hydra 8800 GPU cooler (water block?) discussion thread Misoprostol Water Cooling 9 December 8, 2007 12:27 AM
Another peculiar GPU cooler from Cooler Master: CoolViva Pro Review by X-Bit Babrbarossa Reviews & Articles from the Web 7 March 19, 2007 04:19 AM
