Old December 11, 2008, 05:43 AM
Jackquelegs's Avatar
The PWM control lead is not necessary for functionality.
By the way, you can plug in 4 pin fan plugs into 3 pin headers just fine, if the 3 pin header is enclosed, snap the side off so the extra pin is hanging off the side.
Iapetos
Zephyranthes
