Old December 9, 2008, 07:09 PM
Supergrover's Avatar
Originally Posted by Zippoh View Post
alright broke em off. now i already applied thermal paste to the cpu, do i apply it to the bottom of the cooler too?
I "buff" the base of the cooler with a little TIM pretty much the same as Steve stated except I use a coffee filter for the Cooler and a credit card for applying to the CPU
R.I.P.
Old December 9, 2008, 07:32 PM
I always just fill the gaps of the cooler and wipe any excess then do the normal 2 rice drops on the cpu and squish er down.
Old December 9, 2008, 07:34 PM
so now im installing the MB, does it matter what scew i use? i use the ones that came with the CASE(antec 300)...but i thought metal+mobo=bad?
Old December 9, 2008, 07:39 PM
motherboard has metal bumps around the holes to ground it out.
Make sure standoffs are in correct placement and only 1 type of screw will work for the standoff.
Also make sure IO shield is installed and tabs are UP.
Old December 9, 2008, 07:52 PM
so guys, since i don't have any ram, if I were to power up to make sure everything works, will it break because theres no ram?
Old December 9, 2008, 07:53 PM
nope.
it'll do nothing aside from beep; no video nothing.
Old December 9, 2008, 08:00 PM
do cd drives and hard drives both use the same cables?
Old December 9, 2008, 08:04 PM
yup.
either ide or sata.
  #19 (permalink)
also, are there mother than one power connector for the mobo? like 24pin and a 8 pin?
  #20 (permalink)
Old December 9, 2008, 08:06 PM
Yes power for the motherboard will consist of a 24pin which can be broken into a 24+4 for older boards and as well as a 4x4 pin or a single 4 and single 8 for the EPS plug usually located above cpu.
Problem Installing COD4 rjbarker O/S's, Drivers & General Software 6 November 28, 2008 04:03 AM
Installing Unreal Tournament 3 Mr. Gruntsworthy Gaming 5 October 14, 2008 10:20 PM
no signal after installing new vid card oksir Troubleshooting 13 July 15, 2008 09:27 PM
Installing 3rd Boot with VISTA 64 francois methot O/S's, Drivers & General Software 1 May 31, 2007 02:15 PM
Installing faster RAM on BAD AXE2 francois methot Overclocking, Tweaking and Benchmarking 12 May 13, 2007 02:55 PM
